F2 front brakes single piston wheel cylinders When replacing the single piston wheel cylinder on the early F2 bendix brakes, is it suitable to use the F1 wheel cylinder? I did it along time ago and forgot what i cross referenced as a replacement. I know you have to drill 1 hole to mount the 2 piston wheel cylinder
Re: F2 front brakes single piston wheel cylinders Yes, F-1 or F-100 wheel cylinder.
Re: F2 front brakes single piston wheel cylinders Thanks i appreciate that.
