Flat head RPM range Can any one give me what is considered a safe comfortable rpm range for a stock 42 flathead? Running a 4:11 gear set presently and rpm seems high at highway speeds. Love to install 3:78 gear set but not in the budget as of yet unless one falls into my lap at the right price.
Re: Flat head RPM range My 40 wagon (heavy car) has 4.11s and a small 221 ci stock engine. I don't drive it over 50 on the freeway as I don't want to over rev it. There is a Columbia in its future. I don't have a tachometer just going by sound.
Re: Flat head RPM range Highway cruising in the 2500+- range is economical and does not sound strained. You may need to go to 3.54 gears to get that at 60 mph.
Re: Flat head RPM range My avatar has 3.54s and is about 2600 at 60 mph. No worries on that engine though. drolston is correct.
Re: Flat head RPM range I had a 4.44 in my Ford when I first bought it, and kept up with the traffic at 65mph, although with a frown on my face. The flathead won't redline with a stock distributor, because you'll get point float first.
Edit: I should mention that my engine is a 59L, so it may be higher reving than others. |
Re: Flat head RPM range Quote:
RPM = (Rear Axle Ratio x MPH x 336.13) / Tire Diameter As an example (4.11 x 65 x 336.13) / 29 = 3096 RPM That is not that may RPM. Original Torque/HP curves go to a bit of 4,000. |
Re: Flat head RPM range Here's a calculator I have used to check RPMs at different speeds/differential ratios:
http://www.advanced-ev.com/Calculators/TireSize/ |
Re: Flat head RPM range On my '51, with a slightly modified Mercury engine (Rochester 2G, Edmunds heads, and a Mallory dual point), anything above 2700-2800 starts to get uncomfortable. For me, with the tire size/ rear end ratio I have, that allows me to cruise about 65-70. It will easily go higher than that, and will run over 4000 "going through the gears".
I do not like running it over 4000. It doesn't seem to do any good anyway. |
Where we're all headed, it's more fun to try and get there faster! :cool: |
Re: Flat head RPM range Then on the other hand my father bought a new F6 in Jan 1951 a leftover. Factory
governor says Ford on it probably made by King Seely. Governed at 3000 and yes still has the 'lead seal' its a dump truck and will do 60 empty and just nurse the gas pedal and it may just nick 62. Its purpose was only to kick it up momentarily to the governor then shift it. Got a hard time that people need that 65 70 in any vehicle, now, like from the 1950s 60s when many states with no speed limit. Around here in Masshole takes you 20 min to go a mile in a half. Model T is perfect and I don't live in a city either. |
Re: Flat head RPM range I purposly installed a tachometer to monitor shift points on the flattie. Runs out to 4500 quickly in first gear and with the 4:11 and can practically start in second. At 4500 am I pushing the envelope so to speak? Thoughts?
Frankly at 55mph plus the old girl makes me kind of nervous but then again I'm used to driving my 34 street rod with modern independent suspension and disc brakes. Just saying! Tomorrow I run the flathead out to 50 plus to check rpm's |
Re: Flat head RPM range The 39 with the 60hp (4:44 rear) didn't mind going 65, though it did bring the fuel mileage just under 20 mpg, kept to 55 it was 25 mpg----- and downshifted to second when speed on hills dropped to 40, the 60 hp needs to be above 2500 sometimes, and drove it over 70 on the parkway to keep up with traffic and get a head start on the next hill
Ken http://www.vanpeltsales.com/FH_web/F...39-40_85hp.jpg |
