The Ford Barn
-   -   What is this? (https://www.fordbarn.com/forum/showthread.php?t=280182)
Rockbass 04-28-2020 06:44 PM
What is this?
1 Attachment(s)
Hi All,
The car is 1947 ford sedan mostly original. This part is under the dash on the upper left corner of the firewall. It has no visible wires attached. I would like to know what it is before I take it out. Thanks for your help. Brian
petehoovie 04-28-2020 06:48 PM
Re: What is this?
It's the circuit breaker/resistor board. The resistor steps down the voltage to the coil and the circuit breaker takes the place of a fuse for your lights etc.....
https://www.fordbarn.com/forum/attac...0&d=1588117344
JSeery 04-28-2020 07:44 PM
Re: What is this?
1 Attachment(s)
Yes, ballast resistor and circuit breakers. On a 47 there should be two circuit breakers inside the enclosure, both for the lighting circuits. If it is not connected there must be some major wiring changes. I would guess an added fuse panel and a "can" style coil in place of the original coil. Is it 6v or 12v? Positive ground or negative ground?
19Fordy 04-28-2020 07:49 PM
Re: What is this?
Be very careful not to damage it when you remove it.
JSeery 04-28-2020 07:53 PM
Re: What is this?
Yes, would maybe have some value to someone with original wiring. The ballast resistor repos are total junk.
JayChicago 04-28-2020 10:01 PM
Re: What is this?
re the resistor: Original resistors are available. Those pieces were quite robust, no moving parts, just a big resistor. Most originals still function perfectly well. A few years ago when I thought (wrongly) that I needed one, VanPelt had a stock of them. I would guess that others who deal in original parts do too.
Rockbass 04-29-2020 11:39 AM
Re: What is this?
1 Attachment(s)
Thanks for your replies. I took it out and there was in fact no wires attached to it.
I took a picture of where those heavy gauge yellow wires go to. They are attached to a brown rectangular terminal block which is screwed onto the backside of the gauge cluster panel.
Is this an after market solid state circuit breaker?
FortyNiner 04-29-2020 11:48 AM
Re: What is this?
Does the car with this wiring run?
Rockbass 04-29-2020 12:10 PM
Re: What is this?
Yes, it runs just fine with all electrical components okay. It’s original 6 volt positive ground. Just want to know what I’ve got.
petehoovie 04-29-2020 02:25 PM
Re: What is this?
https://www.fordbarn.com/forum/attac...6&d=1588178278
What's on the other side of those connections???
TJ 04-29-2020 03:00 PM
Re: What is this?
I hope there is a fuse in there somewhere.
Ggmac 04-29-2020 03:37 PM
Re: What is this?
Why remove it ? How many miles on the car ? How many volts at the coil ?
petehoovie 04-29-2020 04:03 PM
Re: What is this?
It's not wired...It's no longer being used....
JSeery 04-29-2020 09:55 PM
Re: What is this?
2 Attachment(s)
I've seen that setup before, it is similar to the 48-49 truck wiring. The first photo is labled as a 47. The device shown is the circuit breakers (2) and a resistor is not needed with the can coil.
petehoovie 04-29-2020 10:15 PM
Re: What is this?
https://www.fordbarn.com/forum/attac...5&d=1588215694
WBrown 04-30-2020 09:32 AM
Re: What is this?
I have the same set up as Rockbass with the resistor attached to the original coil under the hood. The dash set up consists of a junction block with circuit breaker. This is a 6v + ground system, late '47 (Nov) super deluxe 4 door sedan.
Could this be one of Ford's "running changes"!!??
Rockbass 04-30-2020 09:49 AM
Re: What is this?
JSeery, I think you nailed it, thanks for sharing your knowledge. Wow, what a great resource this Fordbarn forum is. Oh, one more quick question, what is a “can” style coil?
Brian
TJ 04-30-2020 10:01 AM
Re: What is this?
The can style coil is the round coil used on the later cars.
V8COOPMAN 04-30-2020 11:16 AM
Re: What is this?
Brian
"Can"-style!
https://5.imimg.com/data5/YL/RV/MY-2...il-500x500.jpg
51 MERC-CT 04-30-2020 03:31 PM
Re: What is this?
1 Attachment(s)
Or get one with your choice of flavors :D
https://www.fordbarn.com/forum/attac...2&d=1588278643
