The Ford Barn
-   -   35 REAR FENDERS vs 36 , (https://www.fordbarn.com/forum/showthread.php?t=279663)
SETHDOUG 04-18-2020 11:23 PM
Bought a 1935 for cabriolet all done except paint ,.
#1 the coup, conv, roadsters , and cabriolet have very different rear fenders that the sedans and wagons ( much narrower )
found this out after and expensive paint job ..
My question to someone with a lotta ford knowledge is ???
Are the 1936 ford rear fenders cpe , roadster and cabriolets
the same as the 1935 rear fenders of the 1935 ????????
V8COOPMAN 04-18-2020 11:34 PM
Re: 35 REAR FENDERS vs 36 ,
Not even close when you look closely! Check below! DD
https://www.fordbarn.com/forum/attac...7&d=1587299093
https://www.fordbarn.com/forum/attac...8&d=1587299093
deuce lover 04-19-2020 12:38 AM
1 Attachment(s)
Coopman's pics didn't show up so here is a pic from the V8 Club book.Suggest you get a copy
rich b 04-19-2020 06:18 AM
2 Attachment(s)
Another comparison
JM 35 Sedan 04-19-2020 07:05 AM
I have an overlay comparison that I saved from Bob Drake's on-line catalog that I had downloaded, but it's saved on my main computer that's unavailable right now. Also, I believe Don Rogers had once poster some type of picture, or instructions on how to ID the differences between coupes/roadsters vs sedans, and '35's vs '36's.
Don Rogers 04-19-2020 07:25 AM
4 Attachment(s)
Here's a comparison that I made between a coupe and sedan rear fender as well as Bob Drake's 35 vs 36 comparisons. Hope it helps.
Kube 04-19-2020 07:36 AM
Wouldn't an "expensive paint job" warrant fitting things BEFORE painting?
deuce_roadster 04-19-2020 09:10 AM
What Kube said for ANY paint job.
TJ 04-19-2020 09:55 AM
When you make mistakes that cost a lot of money you quickly learn to become an expert.
Kube 04-19-2020 10:31 AM
Yes sir! Kind of like measuring twice and cutting once.
RalphM 04-19-2020 10:48 AM
1 Attachment(s)
I wonder how many finished 35’s there are out there with 36 rear fenders, and the owner doesn’t realize it. And vice-versa with 36’s.
While stripping down my 35 coupe noticed an odd repair on the right rear fender, I posted it here on the Ford Barn. When I finally got it completely stripped down I realized what someone had done. They had Grafted on a sedan fender to the remains of a coupe fender.
JM 35 Sedan 04-19-2020 10:51 AM
Don, thank you for posting these pics that I had mentioned in my earlier post. I'll load these into my cell now, so I have them for future reference.
tubman 04-19-2020 11:02 AM
Ralph, If that's a picture of the repair, it looks like the did a pretty good job.
JM 35 Sedan 04-19-2020 11:04 AM
You are 100% correct on this TJ. I've certainly learned from my past mistakes, but for many of us getting up in age....sometimes we forget some of the past, and unfortunately are still condemned to repeat some of our mistakes :confused: :)
TJ 04-19-2020 11:05 AM
Good body work X2
JM 35 Sedan 04-19-2020 11:48 AM
I have a '35 rear fender in my collection that has been modified the same way, but does not look anywhere near as good as the one on your car.
RalphM 04-19-2020 12:07 PM
All leaded in, my guess is it was done in the fifties sometime. Before I stripped it The only sign of it on top was some bubbling through the paint.
rockfla 04-20-2020 06:44 AM
Goes along the lines of that famous statement of all EFV8's........"It's a flathead in it!". IE. 37 with an 8BA "Original Flathead motor!" Don't mean to beat SETHDOUG up!!!!
SETHDOUG 04-20-2020 12:08 PM
V8coopman ,,, please let me say a big thank you for such a detailed answer and help , wow,,, your help is so appreciated ..
Thanks 'seth carley trumbull ct
SETHDOUG 04-20-2020 12:09 PM
Originally Posted by deuce lover (Post 1876418)
coopman's pics didn't show up so here is a pic from the v8 club book.suggest you get a copy
thank you so much for taking time to get me an answer .
Your time is so appreciated ,
seth carley trumbull ct.
