The Ford Barn
-   -   Turn Signal Wiring (https://www.fordbarn.com/forum/showthread.php?t=279292)
shew01 04-11-2020 07:10 PM
Turn Signal Wiring
I recently bought a Signal Stat 900 turn signal switch to replace the existing toggle switch that currently operates the turn signals on my car.
I’m trying to figure out the best way to splice the new switch into the existing wiring (which works fine). The old wiring is cloth wrapped, not plastic wrapped like the signal switch. I bought a separate terminal block (pictured with the signal), but I’m not sure that is the right way to go.
What do you think?
https://uploads.tapatalk-cdn.com/202...0dffe919f8.jpg
https://uploads.tapatalk-cdn.com/202...6c5ceb0fdb.jpg
Patrick L. 04-11-2020 07:14 PM
Re: Turn Signal Wiring
I just strip and twist the wires together [western union], solder and shrink tube them. Then I try to hide them in a woven time period loom.
Badpuppy 04-12-2020 09:43 AM
Forget the terminal block, those are intended to mount in an accessible location (firewall). Splice as Patrick says.
1931 flamingo 04-12-2020 09:50 AM
I used a terminal strip like yours, mounted it with magnet(s) behind the left kick panel along with the flasher. Ran the wires thru the cowl as it looks like yours are. All wires from there out in the fabric loom.
Paul in CT
