The Ford Barn
-   -   aligning a 48 hood (https://www.fordbarn.com/forum/showthread.php?t=279112)
fjz 04-08-2020 06:04 PM
aligning a 48 hood
I am looking for tips. The closest I have been able to get mine is a 1/2" gap. Have new hinges and support arms. I am aiming for a 1/8" gap but would be happy with a 1/4". All suggestions will be much appreciated.
51 MERC-CT 04-08-2020 07:41 PM
Re: aligning a 48 hood
1 Attachment(s)
Try this, loosen the 3 attachment bolts and rotate both sides in the same direction as far as they will go, tighten and check.
You may have to go in the opposite direction but this is a dance that you will have to do in order to get just the right spot.
https://www.fordbarn.com/forum/attac...4&d=1586392932
19Fordy 04-08-2020 07:46 PM
Here's some info about the 40 hood that might help.
Worth a read.
https://www.fordbarn.com/forum/showt...40+sheet+metal
woodiewagon46 04-08-2020 08:07 PM
If you can get a copy of the V-8 Times, dated May/June 2009, there is a detailed two page article on aligning the '41-'48 hood.
Graeme / New Zealand 04-08-2020 08:13 PM
4 Attachment(s)
Here's an article about it . Might have to see if you can blow it up more.
GB
FortyNiner 04-08-2020 08:16 PM
The best reference is an article from the May/June 2009 V8 Times. Reprints are available through the Early Ford V8 Club.
What Woodie said.
fjz 04-08-2020 10:06 PM
Thanks guys. Will try 51 merc's suggestion and attempt to enlarge Graeme's article which appears very detailed.
fordor41 04-08-2020 10:29 PM
remember the more you raise the hinges on the cowl the lower the hood travels down
woodiewagon46 04-09-2020 09:39 AM
Like fordor41 states, every time you move one area, it affects another. If you read the article in the V-8 Times as I suggested you can get a better understanding as how it all works.
corvette8n 04-09-2020 05:14 PM
The V8 Times is available on a flash drive
https://shop.efv8.org/products/50-ye...es-flash-drive
Not only can you find the article on adjusting the hood, plenty of other articles on the '48.
fjz 04-11-2020 06:54 PM
I checked v/8 times and flash drive but can not locate the 09 may june issue. Is there a way?
woodiewagon46 04-11-2020 08:16 PM
If you can't enlarge the instructions that Graeme posted, I can copy it and send it to you by mail.
fjz 04-12-2020 12:32 PM
Thanks for the offer Woodie. Graeme has emailed them to me and hopefully tomorrow when my office opens we can enlarge them.
fordor41 04-13-2020 11:04 PM
Goggle "Mark Kicsak V-8 times". He has an article on aligning a '46-48 hood.
FortyNiner 04-14-2020 05:12 AM
This is the article mentioned in several posts: https://www.earlyfordv8.org/forum/vi...81&sortby=desc
Thanks fordor41!
fjz 04-15-2020 08:39 PM
Thanks FortyNiner. I clicked on the site you posted, now have it saved, and was able to read Mark Kicsak's article. Plan to get back at it again tomorrow.
TJ 04-16-2020 03:38 PM
If you go to the V-8 Club website you can contact the club members who sell the V-8m Club books. If they have the '09 back issue you need you can purchase it.
