36 wiring routing Hi all,
I recently picked up a 36 phaeton in the final stages of assembly after a frame off restoration. The PO passed away before finishing. I'm a long time hot rod guy but this one's pretty much stock (added juice brakes and replaced the missing flathead with a 38 model). Can anyone give me some details on proper routing for the original style wiring harness? Particularly the rear harness and crossover and the front headlight crossover wires? The ignition system is wired and as is the dash. The rear section is pulled down the drivers frame rail. Everything else is just kind of coiled in the engine bay. Where does the rear crossover run? Across the rear spreader? Is there a separate crossover harness for the PS headlight and horn or is it part of that coil? Also can someone post up a pic of how the assembly at the end of the column looks assembled. I think on have the parts but I'm not sure. It doesn't lock into the end of the column How how/where does that harness get to the hear and tail lights inside the fenders? Thanks! |
