The Ford Barn
-   -   Engine facelift (https://www.fordbarn.com/forum/showthread.php?t=278304)
rrich1 03-21-2020 03:01 PM
Engine facelift
Over the past month I did a major engine facelift. I had a few leaks in the radiator and needed to remove it to get them fixed. With the radiator out it allowed me to get at the engine to clean and paint it without removing it. I removed all of the accessories and started to degrease the engine. I wanted to get the transmission done as well but just ran out of time and have other things I need to get done.
New parts included a lower coolant pipe, hoses, fan and miscellaneous hardware like manifold studs and exhaust clamp. Everything else was cleaned and painted. I'm extremely happy with how everything turned out.
The water pump had a piece break off at some point in it's life. It didn't cause any leaks. I repaired the crack and rebuilt it with a leak less kit from Brattons.
https://uploads.tapatalk-cdn.com/202...aabb078260.jpghttps://uploads.tapatalk-cdn.com/202...a716043fb8.jpghttps://uploads.tapatalk-cdn.com/202...916ecc8526.jpghttps://uploads.tapatalk-cdn.com/202...a73220f137.jpghttps://uploads.tapatalk-cdn.com/202...e9fd98cfec.jpghttps://uploads.tapatalk-cdn.com/202...edfab7c8b8.jpghttps://uploads.tapatalk-cdn.com/202...a10c8a9f99.jpghttps://uploads.tapatalk-cdn.com/202...10c0cf4ab8.jpghttps://uploads.tapatalk-cdn.com/202...421a9c8295.jpg
Sent from my Pixel 3 XL using Tapatalk
rrich1 03-21-2020 03:04 PM
Re: Engine facelift
Finished picshttps://uploads.tapatalk-cdn.com/202...544b80d442.jpghttps://uploads.tapatalk-cdn.com/202...dbe3c5bee0.jpghttps://uploads.tapatalk-cdn.com/202...f17e511aed.jpg
Will N 03-21-2020 03:37 PM
Re: Engine facelift
A thing of beauty is a joy forever.
Sunnybrook Farm 03-21-2020 03:41 PM
Re: Engine facelift
That looks good, all pretty and ready for spring. A model A that gets run needs a little engine paint every few decades. I am working on one that has all of the dirt and grease acquired over 91 years on it, amazing how much greasy dirt will stick to one.
Y-Blockhead 03-21-2020 04:28 PM
Re: Engine facelift
Looks good! I like a good looking and clean engine compartment and IMO make it easier to work on.
Brentwood Bob 03-21-2020 04:32 PM
Re: Engine facelift
Sure like the sediment bowl. Excellent job imho.
CC-Mo 03-21-2020 05:27 PM
Re: Engine facelift
Well done!
Russ/40 03-21-2020 05:47 PM
Re: Engine facelift
Very nice, well worth all the hard work.
rrich1 03-21-2020 07:44 PM
Re: Engine facelift
Thanks everyone. It went a lot smoother than I thought. The engine was definitely the eyesore of the truck. Now it looks as good as the rest of the truck.
jimalabam 03-21-2020 08:09 PM
Re: Engine facelift
The first thing when I pop the hood, is it clean and well painted ? Your truck QUALIFIES . Jim Langley...
chrs1961815 03-21-2020 08:15 PM
Re: Engine facelift
Where did you get your engine paint?
rrich1 03-21-2020 08:32 PM
Re: Engine facelift
I got it from Mike's. It's the canned antique country Ford green paint. Not the spray. The spray is more of a hunter green. I like this paint better. Plus a lot more control when painting while still in the vehicle.
old31 03-22-2020 07:35 AM
Re: Engine facelift
Beautiful, I am darn sure you just added 10 HP!
katy 03-22-2020 11:17 AM
Re: Engine facelift
Looking good, but it reminds me of the old saying: "A coat of paint can hide a multitude of sins".
I assume that's not true in this case.
ALJ 03-22-2020 09:00 PM
Re: Engine facelift
Looks good. We used to call that a DuPont overhaul.
David R. 03-23-2020 05:37 AM
Re: Engine facelift
My friend used to say about his wife when she put her makeup on, any old barn looks better with a coat of paint.
ronn 03-23-2020 05:46 AM
Re: Engine facelift
Beautiful, I am darn sure you just added 10 HP! :)
My friend used to say about his wife when she put her makeup on, any old barn looks better with a coat of paint! :)
thanks for making my morning boys!
aford193031 03-24-2020 11:33 AM
Re: Engine facelift
Looks good,
jrelliott 03-24-2020 12:04 PM
Re: Engine facelift
Looks Good. Like new.
rrich1 03-24-2020 02:47 PM
Re: Engine facelift
Thanks everyone. For those that need to clean up their engine I highly encourage it. A little time consuming and no better time now that everyone is on lockdown.
