Bob Drake rear anti-sway kit 1935-40 The small print on this says 35/36 needs to use 37-48 rear end. Can anyone tell me where the difference is that makes it incompatible with stock 35?
Re: Bob Drake rear anti-sway kit 1935-40 The location of the radius rod brackets on the axle tubes.Sent you an email.
Re: Bob Drake rear anti-sway kit 1935-40 And a '37-'40 rear end with torque tube, drive shaft and spring essentially bolts-in dimensionally. That leaves brakes and wheel bolt pattern as about the only details to be addressed. DD
Re: Bob Drake rear anti-sway kit 1935-40 1 Attachment(s)
Little hard to see, but this might show the differences.
Re: Bob Drake rear anti-sway kit 1935-40 Deuce lover tells me he fitted this kit to a 36 and it only needed a couple of brackets welded to the radius rods. Not so easy to find a 37 rear end here.
