The Ford Barn
-   -   Clutch release shaft bushings... (https://www.fordbarn.com/forum/showthread.php?t=276319)
Steve Plucker 02-04-2020 08:22 AM
Who has recently installed the two bushings, right and left, on the bell housing for the clutch release shaft and just where did you get them?
I tried installing some yesterday and they did not fit. Can not remember just where I got them but they were junk!
Thanks.
Pluck
chrs1961815 02-04-2020 08:46 AM
Re: Clutch release shaft bushings...
I did mine a few months ago. Got them from Brattons and they fit fine.
Vin-tin 02-04-2020 09:09 AM
Yea Brattons for me too. Fit was fine.
macdonge 02-04-2020 11:48 AM
I did mine a few weeks ago with a set of bushings from Snyders and they fit just fine.
Steve Plucker 02-04-2020 11:52 AM
Thanks Guys.
Mine must have come from Rick's...Remember that shister? Well...I know some of you do!
Pluck
Benson 02-04-2020 12:07 PM
Does it say Rick Pack on the bag??
Steve Plucker 02-04-2020 12:19 PM
No...But have just leaned something...I had no idea that the 1928 bell housings holes for these bushings are smaller...no wonder they do not fit!
However...I am seeing just one size in Bert's, Brattons and Snyders,,,Am I missing something?
Pluck
chrs1961815 02-04-2020 06:31 PM
Brattons sells the shaft but not the bushings?
F.M. 02-04-2020 07:45 PM
No, The early 28 has NO bushings..
SteveB31 02-04-2020 08:53 PM
Clutch release shaft bushings are the same all Model A years. On the pedal shaft, the 1928 used no bushings in the pedals. 1929-31 used bushings in the pedals that are same as the clutch release shaft bushings. We all currently sell the same brand bushings and they work fine.
Synchro909 02-04-2020 09:12 PM
Sorry Steve, that is fundamentally untrue. The pedal shaft is NOT the same diameter as the release shaft and nobody sells bushes for the pedal shaft nor the shaft itself for that matter. As I have said, the pedal shaft is 1" diameter, not 7/8" like the release shaft
Steve Plucker 02-04-2020 11:29 PM
We are NOT talking about the Clutch and Brake Pedal Shaft A-7506...We are talking about the Clutch Release Shaft A-7510.
Synchro909...Yes, what Steve says is true, bushings are sold for the Clutch and Brake Pedal Shaft for 1929-1931 for the Clutch and Brake Pedals used on that shaft...However that shaft, when mated to the Bell housing has NO bushings there 1928-1931.
Pluck
Steve Plucker 02-04-2020 11:32 PM
YES...The Early 1928 thru production Clutch Release Shaft for which the original post is all about has bushings! Where does it say it did not?
Pluck
Synchro909 02-05-2020 04:54 AM
Pluck
Without wanting to be confrontational, what you guys seem to have missed is that the pedal shaft is NOT the same size as the throwout shaft. The bushes you are referring to (A 7508) will NOT fit. The pedal shaft A 7506 is 7/8" diameter while our pedal shaft is 1" diameter and not available. Sure, those bushes will do the throwout shaft in the bell housing but not the pedals ut you are correct in so far as there are no bushes between the pedal shaft and the bell housing.
Beater 02-05-2020 12:17 PM
I just did mine. both shafts are the same 1" and both shafts take / use the same bushings in the bellhouse and in the pedals.
Werner 02-05-2020 02:39 PM
Pluck,
I built all the parts tree week ago. Came from Bratton's. No problem to mount.
Steve Plucker 02-05-2020 04:05 PM
Found some bushings that work...had to do some reaming out but shaft fits like it is supposed to.
Now on to the next problem.
Pluck
Synchro909 02-05-2020 04:33 PM
Well, I bought a set a while ago. They did the throwout shaft but were waaay too small for the pedal shaft.
I just now measured a throwout fork and the ID of the eye was 22.3mm . That converts to 7/8" as I have said repeatedly and I know the pedal shaft is 1" - the same as the gudgeon pins. A larger shaft for the pedal on our cars makes sense when you consider that the brake pedal, which is the one likely to take the most pressure (in a panic stop) is right out at the opposite end of the shaft from where it is supported by the bell housing. They obviously found that a 7/8" shaft would bend.
Neither shaft nor bushes are available.
KR500 02-11-2020 02:38 AM
Steve, I had found and purchased a Lempco adjustable reamer that is 18inches long and has the tapered aligning sleeves on it so you can get the two bushings reamed in alignment to each other. Otherwise you may have to ream them larger to get the shaft to turn easily in the bell housing.
