The Ford Barn
-   -   Looking for LED replacement bulbs for tail and cowl lights (https://www.fordbarn.com/forum/showthread.php?t=275242)
Conaway2 01-11-2020 06:55 PM
Does anyone know of a good source ? I’m looking for 6 volt bulbs - recently bought a couple that are forward-firing only, and they are not satisfactory.
Thanks - JIm
alexiskai 01-11-2020 06:59 PM
Re: Looking for LED replacement bulbs for tail and cowl lights
I got one of these, seems to work pretty well.
https://modelastore.com/index.php?ro...oduct_id=18460
Merc Cruzer 01-11-2020 07:00 PM
Jim;
They should have what you want:
https://www.ledlight.com/6-volt-posi...ed-lights.aspx
Ted Duke 01-11-2020 07:03 PM
Originally Posted by Merc Cruzer (Post 1840350)
Jim;
What he said!
Ted
Anteek29 01-12-2020 12:05 PM
A big THANKS!
redmodelt 01-12-2020 07:36 PM
LEDLites;
Negative ground Model T, 6 volt system;
Watch the voltage! I got one of the 1129 (single contact even pin brake light) that can be used from 6 up to 24 volts. At 6 volts it puts out very little light. The one I found further down the list is 84776 and is for 6 volts. I have not ordered one yet to try. The 1158 even pin double contact brake/tail seem to be fine but do seem to have some flutter when the standard bulb L or R turn signal is flashing (I have duel taillight with separate tail lights/brake lights from turn signals). Many of the bulbs they have listed are not polarity sensitive so can be used - or + ground. Get the ones that are rated for the voltage you are using. They do have a good description when you click on the ones you are looking at. The 5 I got were shipped unboxed in a padded envelope, keeps the shipping cost down and arrived safe.
Conaway2 01-15-2020 06:45 PM
1 Attachment(s)
Found the perfect bulbs - these work quite well for tail and cowl lights.
https://www.ledlight.com/1129-ba15s-...-2-6-watt.aspx
Jim
redmodelt 01-15-2020 08:04 PM
Are you running 12 volts? Those are the 1129 bulbs I was talking about.
Conaway2 01-15-2020 08:41 PM
No - running the stock 6 volt system.
Badpuppy 01-16-2020 08:46 AM
I ordered 2 of those in 'warm' white for the taillights. Had a pair of bright white before, but fewer SMD chips. Didn't look right to me. Warm white is supposed to mimic incandescent light. We'll see. These are 6-24 volt bulbs, may dim with 6 volt battery-only due to harness/switch resistance. 6V doesn't leave much overhead for their built-in regulators.
Also have same size 6 volt amber bulbs in the cowls for turn signals (w/ 2-bulb headlights).
redmodelt 01-16-2020 11:44 AM
I ran the 1129 shown directly off a good battery for my test. 1129 would be for a stand alone brake light in brightness, the one I tested at 6V was more in the dim tail light range.
Conaway2 01-16-2020 02:06 PM
Actually, the bulb I mentioned is too long for the cowl lights, but great for the tail light, and, if ordered in red, great for the brake light - even behind the amber lens - it’s I’ll lights up as bright red.
BillEbob 01-16-2020 03:35 PM
Jim;
I JUST placed an order with this company. Waiting arrival.
redmodelt 01-16-2020 09:49 PM
This is the one I am going to try next for single contact brake light;
https://www.ledlight.com/1156-miniat...se-60-smd.aspx
marty in Ohio 01-17-2020 09:42 AM
After reading this post last week I ordered the LED bulb from Bert's. It came yesterday. WOW, what a difference!!
Marty
CC-Mo 03-12-2020 01:50 PM
Marty
Did you do headlights & tail lights too? Are you 6 volt?
Any insight appreciated. I'm in the research phase. I'd like to settle on what is brightest for 6 volt. I'm currently getting my '30 fine tuned. Lights are next on my list.
As of now, I have (1) functioning light. A cowl light. Wife is tired of holding spotlight out the window when I drive! Lol.
Conaway2 03-12-2020 04:21 PM
I have LED headlights from LogoLites in my car now, and they are great. Very bright and draw about 2 amps, so the stock 6 volt system easily keep up. I also just received LED headlights from Ledlight.com - they look very similar to LogoLites, but are half the price. I just did a side-by-side test with both this afternoon and it’s hard to see much difference between them. The LogoLites light up the lower led bank on low beam and both lower and upper on high beam. The LED from led light.com lights up half the LEDs on both upper and lower on low beam ,and all of the LEDs on upper and lower on high beam - so they are a little different, but I would need to do a better comparison study when I have more time to see if I can really tell a difference.
CC-Mo 03-12-2020 05:10 PM
Thanks for the info Sir. Do the headlights project pretty good? Also a plug & play, just change the bulbs?
txmike 04-22-2020 09:12 AM
I read the post, lots of good information.
I have a 1929 coupe with one tail light. When I ordered my LED lights from Bratton's the gentleman said to install a ground wire? Can anyone comment on that?
I am not a electrician and appreciate comments on where to install it etc
thanks
Mike
burner31 04-22-2020 10:34 AM
That's what I use, try one in your dome light too.
