Throttle shaft brass plug for zenith carbs Guess this is not available.
Anyone know where I can purchase these? Renners had one. Shaped like a welsh plug. |
Re: Throttle shaft brass plug for zenith carbs Sacramento vintage describes the part as: throttle shaft end plug.
I saw it listed in a United Kingdom supplier online catalog. |
Re: Throttle shaft brass plug for zenith carbs I seal that by putting some oil on the end of the shaft and some epoxy putty over it. The oil prevents the epoxy sticking to the shaft. It is on the hidden side of the carby and my car is a driver so that's fine by me.
Re: Throttle shaft brass plug for zenith carbs By chance does A&L have them? I bought some a couple of years ago. I just don't remember who I got them from.
Re: Throttle shaft brass plug for zenith carbs Quote:
Re: Throttle shaft brass plug for zenith carbs I think Bratton's carries them??:confused:
Bob-A:D |
Re: Throttle shaft brass plug for zenith carbs Nobody has made them for 6 years.
Re: Throttle shaft brass plug for zenith carbs 1. I use a sheet of flat plastic ... the kind that those plastic "blister" packages that are almost indestructible are made of.
2. Punch a hole with one of those hand paper punches that punches one hole and save the "hole". click link for photo https://www.carlmfg.com/medium-duty-single-hole-punch/ 3. Put the "hole" inside throttle shaft bushing area.("Hole" keeps shaft from getting stuck to JB Weld) 4. Then as mentioned above use J B Weld to fill hole even with the casting. 5. Powder coating or painting does not affect J B Weld. |
Re: Throttle shaft brass plug for zenith carbs Looks like I am SOOL.
Re: Throttle shaft brass plug for zenith carbs Elusive. Maybe offshore? New Zealand?
Re: Throttle shaft brass plug for zenith carbs I have used a brass shell casing,file the rim,and insert with small amount jb weld. I think it was a 22 or 17mm casing? not sure on size, looked nice and authentic. Have to look in my files as to the exact size of shell.
Re: Throttle shaft brass plug for zenith carbs That crossed my mind. A rim fire cartridge?
Thanks for the idea. |
Re: Throttle shaft brass plug for zenith carbs or get some of the brass tubing that is sold in the hobby display at most hardware/crafts stores cut a piece off and solder on a disk. If it fits a little lose, use some JB Weld.
Re: Throttle shaft brass plug for zenith carbs I cut a piece of oversized brass rod and used my lathe to make it fit.
Re: Throttle shaft brass plug for zenith carbs No lathe here, but I like the shell casing idea, or the tubing.
Re: Throttle shaft brass plug for zenith carbs I contacted Bratton's about the brass plugs. They said the individual who was making them passed away and the punch/dies used to make them were lost. Not enough demand to make anymore tools needed to create the plugs.
Bob-A:D |
Re: Throttle shaft brass plug for zenith carbs Not good news.
Re: Throttle shaft brass plug for zenith carbs |
Re: Throttle shaft brass plug for zenith carbs Thanks, sent a pm.
