The Ford Barn
-   -   a hole in my floorboard??!! (https://www.fordbarn.com/forum/showthread.php?t=274919)
Club Coupe 01-04-2020 05:40 PM
I am considering putting an OD tranny in my 1950 Ford. I have a rebuilt one available for $700. After reading and watching YouTube videos it seems that (among other things) I will need to drill a hole in the floorboard under the accelerator pedal for a kickdown switch. Is this true? Bummer
Bob C 01-04-2020 06:25 PM
Re: a hole in my floorboard??!!
Look at the floor, there may be a knock-out there. When I did my 49 there was one.
May get more answers on the early V8 section.
Bob
Charlie Stephens 01-04-2020 07:26 PM
Bob,
Sorry I pointed you to the wrong forum. I was in a hurry and had Model A's on my mind. The correct forum should be, as Bob noted: https://www.fordbarn.com/forum/forumdisplay.php?f=4
Charlie Stephens
rotorwrench 01-04-2020 07:39 PM
I would recommend that you set it up just like the factory. This would include the cable pull assembly, dash relay, and kick down. The transmission should come with the governor switch and the operating solenoid but if not, you will need those too. The drive shaft should work as is. New electrical harnesses are available too.
The factory set up will insure all the reverse lock out, kick down, and on speed functions will be automatic. All you have to do is follow the operating instructions in the owner's manual. They work really well this way. They rear axle likes about a 4.10:1 ratio but it will still work with a taller gear as long as it isn't too tall. If yours had a standard transmission before, it should have a 3.73:1 ratio which will work. It will get up to higher speeds with lower rpms that way.
