Making an old radiator grill look good I have an original 32 radiator grill. It looks like it has some sort of plating. Is it nickel or chrome or ?. It is very tarnished but no rust. Finns are all very straight. What Is the best way get it shined up or at least close.
Thinking of Never Dull or the like |
Re: Making an old radiator grill look good Quote:
Re: Making an old radiator grill look good Hi; plating shops can 'strip' old plating off. Newc
Re: Making an old radiator grill look good Will not look forward to taking that grill apart, getting it stripped then putting it all back together. And the lack of plating plants is another problem
Re: Making an old radiator grill look good I've done this a number of times and it works. Try soaking it overnight in Coca-Cola, the original coke. Find a shallow containor it will fit in and go get about $20 worth of 2 liter bottles and fill it up, let it set overnight and rinse with water. Then polish as desired. I don't think Nev-r-dull works well on anything but bare metal but a good auto or chrome polish coupled with good old fashioned elbow grease should produce deisred results.
Re: Making an old radiator grill look good Forgot to mention if it doesn't work as desired you're only out the cost of the Coke, but it certainly worked well for me, particularly on a set of tarnished and crusty hubcaps from a '49 Nash. I was amazed.
GB |
Re: Making an old radiator grill look good If its the perimeter - should be stainless and just some fine steel wool will wake it up.
Re: Making an old radiator grill look good Steel wool works wonders. I used it on every piece of stainless and chrome on my Mercury.
Re: Making an old radiator grill look good I’m sure it was just sarcastic humor from Tom:o
Re: Making an old radiator grill look good After soaking it in Coke rub with aluminum foil. Works wonders.
Re: Making an old radiator grill look good The grill was not originally plated. They were painted. Do you have an original grill? Most aftermarket ones were plated. I might just run some fine sandpaper over the bars and paint them.
Original bars are easy enough to remove. Gently pry them up from the cross support bars and bend them sideways and get an end out and then the other. |
Re: Making an old radiator grill look good If you use steel wool, make sure to use "0000" grade, anything else may leave very fine scratches.
Re: Making an old radiator grill look good It is an original grill. I did not know it was stainless. I have a container to soak it in. I think I will find some very fine steal wool and try that before I buy 8 gallons of Coke. I cannot afford that much Jack. How about 1000 grit wet dry
Re: Making an old radiator grill look good The only stainless is the outer band. I would not sand it. Just some polishing should bring it back. I was talking about the bars when I mentioned sanding.
