Remove inner oil pan 1 Attachment(s)
Hallo,
does anyone have a suggestion how I pull out the corrugated iron insert-pan off the whole oil pan? (Tiny rust holes!) |
Re: Remove inner oil pan Believe it or not a Wooden baseball bat slid into the side and give it a good pop it will come out.
Re: Remove inner oil pan Put a piece of old junk carpet on the ground and drop the pan upside down on the carpet it will just pop out . You might have to assist gravity a litle bit .Dont do it on bare concrete .
John in no weather today Suffolk County England . |
Re: Remove inner oil pan Best to put the pan in a plastic garbage bay prior to dropping. It will contain the sludge!!
Re: Remove inner oil pan Quote:
Tom Endy |
Re: Remove inner oil pan if you slip the other side under the overhang of a step ---arm of the lift, or watever is handy to hold the pan then the baseball bat gives more control ---less splashing of gook
Re: Remove inner oil pan Hmmm, do they have baseball bats in Germany??
Re: Remove inner oil pan The easiest of all way is to place a C-clamp inside the oil pump opening and lay a 2x4 in. piece of wood across the top of the oil pan. Simply wind up the C-clamp and out pops the dipper try. Ed
Re: Remove inner oil pan 2 Attachment(s)
I do it this way and it is sooooo easy
Re: Remove inner oil pan Make sure when you replace the baffle it snaps totaly in place, check and double check! You do not want to drop the pan for a do over.
Remove slot screw plug and insert holder, remember to remove holder and insert plug when job is complete.
Here is another version of the holder |
Re: Remove inner oil pan Whoops... wrong thread...LOL
Re: Remove inner oil pan 1 Attachment(s)
I did it similar to PalAl. That worked well, thanks for the hint!
Again, it is easy to see how clean the interior of a motor is, if it is lubricated with HD oil SC. Minimal hardly any residues in the oil pan. |
Re: Remove inner oil pan The last time I needed to remove the dipper tray from an oil pan, I had a 28-29 headlight bar on the bench that I tried to see if it would be a good pry bar. The curve on the end and the flange for the mounting bolts works perfectly as a pry bar. Use your foot on the pan and with the headlight bar, the dipper tray will pop right out.
My experience, Chris W. |
Re: Remove inner oil pan I did like John said: tied it up in trash bag, held it up about head high, dropped it top side down on a piece of plywood on concrete driveway and popped right out first try. Boy was it grungy though!
Re: Remove inner oil pan https://www.fordbarn.com/forum/hamb/misc/menu_open.gif https://www.fordbarn.com/forum/hamb/...n/post_old.gif 12-01-2018, 03:59 PM #1 davehc
Senior Member https://www.fordbarn.com/forum/image...ine=1385340687 Join Date: Aug 2012 Location: Adrian , Mich. Posts: 362 https://www.fordbarn.com/forum/images/icons/icon1.gif Easy Oil Pan Baffel Removel Thought I would share how I removed the baffle from my oil pan after I finally got if off , for those who haven't tried this yet . . I used my slide hammer with the small hook , with a rubber cap to protect the baffle , hooked it in the small hole side of the baffle , and it popped out on the second slide . Attached Thumbnails https://www.fordbarn.com/forum/attac...1&d=1543693966 |
Re: Remove inner oil pan When you have the dipper tray out and cleaned, hold it up so sunlight will shine on it and check for rusted through spots. Water will settle in the dipper troughs and rust them.
Guten Abend Jim,
here at this point I have to enjoy myself. When I had the tub solved yesterday, I saw some rough areas (like rice) below. I soldered them hard today! |
