Bendix Spring bolts A question comes up periodically at the club meetings regarding the bendix spring bolts. Should they be tight against the spring or slightly loose, with the tabs on the washer keeping the bolts from backing out. Thanks.
AL |
Re: Bendix Spring bolts If they are tight, and fit the threads tight rarely will they come loose or break--- when they are run loose the threads wear and there's more bending motions to fatigue the bolts----
I don't run starter on 12 volts, but I have used the starter to drive the car out of the garage to work on the not running car to get in better light, and when the clutch was stuck I would start the car in first, drive shifting without the clutch, stopping the engine at light and stop signs---- the car has been putting up with my uses of it with few complaints, 35 years ago I took a bendix I got in the trash and used new bolts and locks--- I would guess that starting in gear is harder on it than 12 volts |
Re: Bendix Spring bolts The Bendix starter drives were troublesome throughout the Model "A" years judging by the quantity of service bulletins issued about them. My comments regard the A-11350-C Drive.
Refer to the Ford Service Bulletin for June 1931, Pages 570, 571 & 572. Starter Spring Clips A-11383 were installed on the drive to provide a bearing surface for the first 1/4 coil on each end of the spring. So these clips put sheet metal between the spring eyes and the drive body. On Page 572 at the bottom of the spring clip text, there is a paragraph warning not to tighten the spring screws to the point where the spring eye cuts into the clips. The spring is going to elongate and put a twisting torque on the spring screws regardless of how tight the screws are. If the screws are tight, they will cause acceleration of wear on the spring clips, the spring eyes and the spring screw heads. Because of the twisting torque of the spring eyes, Ford put special anti-rotation lock washers on the drive to engage the screw heads and drive body. Besides the special lock washers, I suggest you use a thread locking compound. The diameter of the Bendix bolts changed from 5/16" to 3/8" when the V8 went into production. The V8 Starter Drives are interchangeable with the Model "A" drives. The ultimate solution for Bendix drive problems, the most notorious of which is broken screws in the flywheel housing, is to use a quality-made modern starter drive. |
Re: Bendix Spring bolts Recently I have run into two starter dives that had a 5/16” bolt in the spring on the starter end and a 3/8” bolt in the hole in the A-13357 sleeve end of the shaft.
Was this done at the factory or done to attach the new A-11357 starter drive sleeve which only comes with the 3/8” threaded hole? Snyder sells a package of 2-3/8” bolts or a package of 2-5/16” bolts. The sleeves did not have the slots milled on each side as called out in Snyder’s catalog. |
Re: Bendix Spring bolts 1 Attachment(s)
This is the cure for all Bendix problems.
Re: Bendix Spring bolts Except when the starter fails on a tour and you have to drain the radiator and block, remove the water inlet to the block to get the starter and Bendix off the engine.
Re: Bendix Spring bolts Quote:
I still hand prop my Cub but the lever arm is much longer on that. |
Re: Bendix Spring bolts The fastener threads must somehow be tight to prevent the threads from moving. Retainer compound is a very good suggestion in addition to the clips.
Re: Bendix Spring bolts This is probably the bendix Bob is talking about.https://youtu.be/0Iwdq5Uml00?si=IIld0kQcgkjmbPHR
Re: Bendix Spring bolts I can get the starter motor that is equipped with a modern starter drive in out without disturbing the coolant lines in both of my 1931 Model A's.
Re: Bendix Spring bolts Maybe my problem removing the starter with the modern Bendix is the F100 steering column???
I turned every which way and couldn’t get it around the the water inlet and steering column. |
