gas what can you use to clean a gas tank of 15 year old gas, varnish.
Re: gas Fresh gasoline with 15% alcohol
Re: gas POR 15 cleaner/degreaser,(formally called marine clean)
Re: gas Drano crystals & water work but be careful mixing and handling. Sodium Hydroxide, or Lye for short, can burn you but it works really well to remove crap from a gas tank without hurting the metal.
Re: gas I didn't find it difficult to just remove the whole tank, and clean it.
Re: gas Quote:
Re: gas When using lye or Drano, is a final flush of baking soda/water needed?
Re: gas Lye is a Base chemical so baking soda won't help.
Re: gas Lye would be diluted by fresh water rinsing. Water can be removed with alcohol, It can rust up with bare metal so it should be either put back into service or sealed to prevent corrosion unless it already has corrosion in there. Lye won't take the corrosion out. It's too bad that the terne plate doesn't last very well but that's what Ford used to seal them with.
