Shifter tower blues 2 Attachment(s)
We go through this with every transmission shifter housing and every core shifter housing that comes through our shop. Each one is oven baked and media blasted to clean away all the grease, oil, dirt, and rust. Sometimes, they look okay after we take them apart, go through the cleaning process, and then we discover the hidden problems. Believe it or not, the corroded tower actually looked useable before we cleaned it. Sadly, the corrosion also entered the detent plug holes where the threaded section holds the plugs.....badly damaging the threads. The other tower came through the process looking fine...…..until we saw the crack in the casting where a shift rail passes. Both towers had to be rejected for rebuilding purposes. This cleaning and inspection occurs with each and every casting we handle.
Re: Shifter tower blues Damn! its shame towers, and good cases are what we need ; o )
Re: Shifter tower blues Glad I joined Ford Barn to see this.
Re: Shifter tower blues I sent some 78 cases out to be sand blasted. One came back with a small crack near the inspection cover. Sent it out to the micro welder. They had it for a week they tried to stop it from cracking but every time they let it cool down it the crack would show up. It's a shame I had to scrap it because they are getting hard to find good ones.
