The Ford Barn
-   -   Engine won"t idle (https://www.fordbarn.com/forum/showthread.php?t=271531)
rocket1 10-25-2019 07:28 AM
Engine won"t idle
On returning from a 60 mile ride whenever I stopped the engine would die,checking it out at home I could hear a miss in the exhaust pipe and a crackling noise at the carb.I took a compression test and found only 40 lbs at number one cylinder and 60 to 70 on the others.I pressurized #1 cylinder with 60 lbs air at top dead center,air leaks out the carb;also with the #2 plug out the air will come out #2 cylinder while #1 is under pressure.I assume #1 intake valve is not seating or burned but why is air coming out # 2 plug hole?
Ray64 10-25-2019 08:03 AM
Re: Engine won"t idle
Head Gasket? Maybe valves #2 also
29closedcabguy 10-25-2019 08:30 AM
If #1 is finishing compression cycle and the intake valve is not completely closing and #2 is in it's intake cycle with the intake valve open you could have this condition. You might try your test with the #1 piston more retarded in its relative position were the #2 intake is positively closed.
Bob Bidonde 10-25-2019 09:29 AM
You have done the right checks, so it's time to remove the cylinder head, and open the valve chamber. Your best expectation should be a failed head gasket and a burned valve.
Bob C 10-25-2019 10:46 AM
Don't think there would be good compression in #2 if gasket was blown between 1&2.
Patrick L. 10-25-2019 02:06 PM
I don't think I'd worry about the head gasket just yet. Could the #1 hole have a sticky valve ? Have you checked the lash on that valve ? If that valve is bad it could leak into #2, in that case the head would need to come off.
Purdy Swoft 10-25-2019 08:43 PM
Check for vacume leaks .
