The Ford Barn
-   -   Model A Volt Meter (https://www.fordbarn.com/forum/showthread.php?t=271300)
Ak Sourdough 10-21-2019 03:05 PM
Model A Volt Meter
Does anyone know of a volt meter made for 6 volt + ground systems that will fit the Model A panel and look vintage?
Bill Pursel 10-21-2019 04:50 PM
Re: Model A Volt Meter
Macs and Snyders sells replacements for the Model A
Patrick L. 10-21-2019 06:15 PM
Volt or amp ?
Badpuppy 10-22-2019 10:50 AM
These are for T (negative ground), FP doesn't make them for the A.
http://www.funprojects.com/products/5016-Voltmeter.aspx
Maybe contact them and see if they can be connected for pos. ground. I would say it's possible, if the housing is isolated.
Also, idk if T and A are same size.
alexiskai 10-22-2019 10:56 AM
Wouldn't you just reverse the leads for positive ground? Volts are volts.
Ak Sourdough 10-23-2019 01:24 AM
Thanks badpuppy, that might work. I'll contact them and see if they'll give me the diameter and depth. I might be able to attach that big flange to the back of my panel with some thick gooey double sticky tape, that stuff is wonderful. I like the face.
Alexiskai, yes, switching the leads should make it work on either ground system. I read their installation instructions and the illustration shows + and - terminals on the back so the case is not involved.
Thanks guys, anyone else have any ideas?
redmodelt 10-23-2019 02:02 AM
As was said volts is volts, don't mater if 6, 12. As long as the meter is made for more then the highest output from the source.
google search;
https://www.google.com/search?client...volt+meter+car
The meters shown are going to be bigger then stock A meter. The depth should be ok if mounted on the face of the instrument panel like the A, but the diameter of the face is larger and flange even more so. I don't have one in front of me and it's too late to go out to the shop a check.
Badpuppy 10-23-2019 11:23 AM
Quite probably true, but verify with them for sure. If the case is common with the (-) terminal you could get a shower of sparks. And dash depth is limited - the unit may not fit entirely behind the bezel.
