The Ford Barn
-   -   Flathead Fan Oil (https://www.fordbarn.com/forum/showthread.php?t=270679)
Eagle43 10-09-2019 10:26 PM
Flathead Fan Oil
I took apart the fan assembly that I plan to install on my 8BA flathead in order to clean and paint and was surprised to find that the hub was filled with oil and some water. What is the purpose of this oil besides lubrication? How much and what weight of oil should I put back in when I get it back together? The fan comes from what I think is a 1948 M2.
estout81 10-09-2019 10:33 PM
Re: Flathead Fan Oil
I use 30W in my fan on my '48 F-1. Check it every time I change oil.
adileo 10-10-2019 05:43 AM
Shop manual says 1 oz. then with screw out rotate so filler hole is at bottom (paper towel under it) then rotate back and put screw back in. . I also used 30w
Ken/Alabama 10-10-2019 08:28 AM
Hypoid gear oil.
oldskool 10-10-2019 09:36 AM
Originally Posted by Ken/Alabama (Post 1808189)
Hypoid gear oil.
yes ford revised to use gear oil instead of 30w
Eagle43 10-11-2019 12:19 AM
Thanks everyone. Gear oil it will be.
Tinker 10-11-2019 02:04 AM
Ya most it's mentioned is your year service lube and maybe oil. Is to put some oil (engine oil) in the cup really. 30w then
