Reliability Looking for opinions: I want to make a 1930 A as reliable as possible. I want a driver.
What do up feel provides the best dependability and why? Please prioritize. completer 12 volt conversion generator to alternator electronic distributor diode version cut out (positive or negative ground, depending on conversion) electronic voltage regular cur out, 6 volt positive ground conversion of 2 blade fan temp gauge oil press gauge oil filter air filter other Thanks in advance. |
Re: Reliability A competent rebuild of the engine. All else flows from there.
Re: Reliability Top of the list for me is
1) gentle driving - no thrashing 2) regular checking and regular lube 3) have a decent battery but from your choices I'd go a) generator to alternator b) get a good 2 blade fan and not worry about the rest:) |
Re: Reliability Quote:
I would insure ALL systems are in top condition. Not only the engine as PC/SR has suggested, but the fuel system, electrical system, suspension, steering, brakes, etc. All need to be examined closely (with help from an expert if necessary) and put into "as new" condition. This will do far more for dependability than replacing distributors, generators, adding gauges, etc. Just my opinion. |
Re: Reliability well said, Dick!
Re: Reliability I agree with all the above. For more driving pleasure, I would add a little power and an overdrive. A 6:1 compression head and downdraft carb will give a surprising increase, and not hurt reliability at all.
Re: Reliability If the car is running and driving I would first start with steering and brakes. Take it all back to Ford specs or pursue any of the many "upgrade" options. Properly done though, stock brakes and steering will be as good as anything. Somewhat mixed in with steering and brakes is suspension. Need to make sure springs and shocks are doing their job and repair/replace as required.
What kind of shape is your car in currently? Gauges and filters won't make the car any more reliable. What you want is to have a car where you don't have to worry about what a gauge is reading. As far as electrical reliability, a good generator, good restored distributor with stock points and dedicated grounds would be tops on my list. My car is almost stock with the exception of a 5.5 head, cast iron brake drums and voltage regulator in the generator. I need to do some rehab on the steering and brakes but once that's done I won't have any reservations about taking the car anywhere. |
Re: Reliability I agree with Dick. Enjoy.
Re: Reliability One thing I think people overlook in reliability discussions is that sometimes the most reliable choice is the one that you understand the best, can maintain, have the right tools for, have a spare, etc.
If you replace the distributor with an electronic one, and it works great for a couple years and then dies on the side of the road somewhere, and you can't fix it and you don't have a spare, was that really more reliable than the stock distributor, which might need more TLC but which is easy to repair with basic tools? |
Re: Reliability On my roadster , I run a stock generator on twelve volts with a Fun projects voltage regulator , modern starter drive . Pertronix flame thrower coil , original points , brass rear water pump bushing with two seals , balanced aluminum two blade fan , eight fins per inch radiator , temperature gauge, I feel that a temperature gauge is the most important extra gauge to add . Bronze cam timing gear , adjustable lifters with a Winfield super street 3/4 race camshaft . dual updraft model B carburetors . 5.9 BF head and a lighter model B flywheel . I run the original 3.78 gear ratio to maintain low end torque and mid range power . The pep and power to get out of the way is as important as reliability to me . I run a 1.5 inch shorter pitman arm for ease of steering , original brakes with cast iron front brake drums . and probably a few other minor mods that I don't recall off the top of my head at this time .
Re: Reliability You emphasize RELIABILITY.
complete 12 volt conversion, No reliability gain, some convenience due to commonness of 12V neg gnd generator to alternator no reliability gain, does give you some higher current light bulb options electronic distributor No reliability gain, less repairable on the roadside, upside is no point adjustment or cleaning necessary, more gain towards convenience diode version cut out (positive or negative ground, depending on conversion)No gain in reliability over stock original, if you have a repro, then yes a diode adds reliability electronic voltage regular cutout, 6 volt positive groundpossible reliability gain due to longer battery life due to proper charging, possible reliability loss if you try jumping the car, it can destroy a voltage regulator conversion of 2 blade fanaluminum 2 blade fan is definitely an improvement in reliability over a stock original that is likely rusted on the inside and could lose a blade unexpectedly temp gauge Not really a reliability gain but will allow you to keep better track of the engine cooling system so if problems develop you can detect the problem and address it before you are sitting roadside with Old Faithful spewing coolant all over oil press gauge Can't really see much advantage at all as standard oil pressure on an A is pretty close to none oil filter Convenience mainly, won't have to change oil as often air filterif you travel gravel/dirt roads much it could be a significant reliability gain in the form of less oil changes and longer engine life |
Re: Reliability Reliability ? Just make the car as safe as can be, steering, brakes, etc.
As said, the 2 newer blade fan change and an electronic voltage regulator are good changes. But, thats it. These cars are pretty bullet-proof. |
Re: Reliability Alternator does provide steady voltage,increasing the longevity of all electrical components,bulbs,horns switches and the coil all perform better.
electronic distributor provides a clear constant impulse to the coil,resulting in a consistent spark at the plugs and more importantly mechanical spark advance,insuring an accurate timing no matter what the engine rpm is.This is a great reliability factor over manual spark.Combustion chamber stays cleaner and cooler,leading to longer piston ring and valve life.Spark knock is eliminated,ending one of the main causes of premature center main bearing failure. Full flow engine oil filter collects debris in suspension of the oil.This greatly reduces engine wear and maintains engine internal cleanliness as opposed to constantly recirculating dirt and debris through engine bearings. air filter on dirt roads? not necessary if your the lead dog,vital if your in the pack. raising compression and increasing fuel creates an more efficient burn,meaning better fuel mileage and a cooler running engine. |
Re: Reliability A couple of things i have done include:
Battery isolator switch Fuse mounted to the starter Sealed water pump 1935 16" rims with radials Counter balanced crankshaft with harmonic balancer, lightened flywheel v8 clutch floater engine mounts Shorter droparm Things I could suggest: LED headlight bulbs Overdrive New brake drums Shocks Depends on how far from original you want to go.. Because then you get the syncro gearboxes and F100 steering boxes etc. Steve |
Re: Reliability I do get better gas mileage with dual up draft B carbs and higher compression than I do with a single model A Zenith carburetor on a stock engine . They seem to run cooler with reasonably higher compression .. I agree that an alternator is the best way to go but ..I prefer the generator in most cases for original appearance. I can work on and usually fix generators but not so with alternators . Modern cars use electronic ignition and it is far superior to the model A distributor . I know nothing about electronic ignition and the least problem with it would leave me stranded . I'm only a fairly good shade tree mechanic but I can usually deal with the model A distributor . There is a big reliability advantage with modern distributors . I've got Mallory dual point distributers from the nineties and the only thing that I have had to replace on them so far was condensers . They increase the spark , of course the higher the RPM the higher the increase , to a point . The Mallory distributors have automatic advance but I still like to do the advance myself with an original distributor . I feel that air filters do more harm than good and restrict power . Model A's have survived for over ninety years in many cases without an air filter . An oil filter would add longer engine life . Oil filters are hard to conceal and I just don't like the looks on my model A . Again many model A's have survived over ninety years without one . I've run model A's without an oil filter for nearly 59 years .
Re: Reliability After 90 years, I would say that is reliable all in and of itself. Other than that, I suppose it depends on whether you live in a place where your daily driving is going to be confined to regular city and neighborhood streets or freeway or some combination of the two. If you want to enjoy the car as a stock Model A, then I wouldn't drive it like a modern car unless you want to turn it into a modern car that happens to look like a Model A on the outside.
Remember the Model A engines don't last like new cars and they have to be constantly lubed and oil changed if stock. If you *ARE* going to drive it daily, I think you should put seat belts in it, especially if you have family. A turn signal would not hurt either. Make sure lights and brakes are in the best working order you can muster. Stock points ignition is pretty damned reliable as is the stock carburetor. I think a generator versus alternator is just as reliable as the other, but whether you go to an alternator might have to do with what kind of headlights you run and the ability for the generator to keep up in the case of Halogen lamps. |
Re: Reliability The real question is what do you want..A pure stock model a ford properly maintained is reliable.a fully modified touring model A properly maintained is reliable. The two styles are different enough where a fella could own both kinds and be happy.
Re: Reliability If you want reliability, then go through everything and do it right. No shortcuts, Jerry rigging, worn out parts, ect. Then you’ll have reliability. It ain’t cheap.
Re: Reliability There's a different kind of reliability in a properly restored To original A, when you have a problem usually it is something simple that can be fixed alongside the road---- a modern car has different reliability, they go a long ways, but when it dies it has to be towed to a shop---- too many "modern modifications and you have old car that has to be towed
Re: Reliability Over a period of many years I have read the stories of long distance trips, sometimes one car, other times a group of cars. In most instances the breakdowns are cars with one or more modifications. The basic cars like Henry made just keep going. My own Model A's have zero modifications and when younger drove many many long trips and got home with no problem. I suggest you tear up that list, keep the car stock and if you want to do some work on it make sure you have good brakes.
A Model A that is stock is your friend, not your enemy! Model A owner since 1937, 65 year MARC member. |
