Zenith Carb I have several zenith carbs that I will never need. What are they worth
Re: Zenith Carb From 0 to 2 or 3 hundred dollars depending on what shape there in.
Re: Zenith Carb For reference - Bert's rebuilt Zenith Carbs that use flow tested jets and tested on an A, run about I believe $350 without a core. So as Fred says, depends on what condition, if they have been tested on a car, and what someone will pay for them.
Re: Zenith Carb Do u have a zenith 3?
Re: Zenith Carb 3 Attachment(s)
Re: Zenith Carb I will likely buy them for $50 each. But would love to see photos first.
Steve |
Re: Zenith Carb Zenith three carburetors are few and far between .
Re: Zenith Carb Zenith 3 carbs used less cast iron than 1 or 2.
Re: Zenith Carb how about a Holley? H on the upper half?
B carbs? |
Re: Zenith Carb Quote:
Re: Zenith Carb Are these cores or re-built??
Paul in CT |
Re: Zenith Carb Model B carburetors are thin and the upper flange is easily broken . I also have a couple of brazed upper model B carb housings .
Re: Zenith Carb They are not rebuilt !
Re: Zenith Carb I think I will keep all fifty of them, I thought that rebuilt sells for $ 350.00 with your core that these would be worth some money,my mistake
Re: Zenith Carb there is a guy selling rebuilds for 170 on ebay. they go on ebay rough 50 nice may work by the look of it 100-125
Re: Zenith Carb Pictures are posted of the Zenith # 3 Carbs..
Re: Zenith Carb I think that Rex Reheis discovered several Zenith 3 carburetors sometime in the 90s . There was a write up in one of the national model A magazines about the carburetors and their discovery . A lot of model A guys , myself included had never seen or heard of a Zenith 3 at the time .I would consider them to be collectors items .
Re: Zenith Carb I have seen one complete Upper/Lower and ONE and a half lower castings.
I say 1/2 because one lower casting was a Zenith 2 which someone used a Dremel in a feeble attempt to make the 2 into a 3 ... was sold on Ebay as I remember. |
