The Ford Barn
-   -   What’s this Box??? (https://www.fordbarn.com/forum/showthread.php?t=267523)
Tveditr 08-07-2019 04:35 PM
What’s this Box???
I need help. Trying to sort out the wiring on a 1930 Model A . The previous owner has a bunch of wires going to a box on the firewall which looks kind of like a voltage regulator. Any help deciphering this would be great. I’m not sure it’s working properly. I am getting bad voltage drain from somewhere.
Thanks
whirnot 08-07-2019 04:58 PM
Re: What’s this Box???
1 Attachment(s)
Hope this helps
Chuck Dempsey 08-07-2019 05:41 PM
Your 'box' in question is the 'terminal box', in Whirnot's diagram. Left-right doesn't matter so much as getting all of the wires aligned on the appropriate side......
Charlie Stephens 08-07-2019 06:00 PM
Thanks
A picture would be great.
Charlie Stephens
Patrick L. 08-07-2019 07:07 PM
If the 'box' you're talking about is in the middle top of the firewall and made of black bakelite with 2 thumb screws, then its the terminal box and is supposed to be there.
As mentioned, a picture would help.
Stick a volt meter or test light between battery terminal and battery post to see if there is a draw. If the light lights just keep disconnecting stuff until the light goes out, thats your draw. One place to check is the brake lights, the switch is kinda famous for sticking.
Charlie Stephens 08-07-2019 07:58 PM
1 Attachment(s)
Here is the box that is being discussed.
Charlie Stephens
daren007 08-07-2019 08:15 PM
Disconnect it and see what happens.
ursus 08-07-2019 09:30 PM
My car had a box on the firewall in that same position and it contained about six fuses for various branches of the wiring system. Pull off the cover and look inside.
Bob from Northport 08-07-2019 09:54 PM
It a fuse box Open it up.
Tveditr 08-08-2019 06:32 AM
I don’t think it’s the terminal box, as that is located in a more central location on the firewall. This is located on driver side.
dpson 08-08-2019 06:44 AM
Pandora's box?
rotorwrench 08-08-2019 09:07 AM
Some sort of an add on aftermarket unit. It's likely a distribution panel for accessories but it's hard to say without seeing inside and knowing where the added wires go.
CarlG 08-09-2019 01:31 PM
Looks like there is a fuse missing right at the top of the box.
Definitely an aftermarket add-on.
CWPASADENA 08-09-2019 11:30 PM
That is a dual circuit head light relay. It helped to get full voltage to the headlights.
Not too uncommon in the old days.
You do not need it if everything is in good condition.
Chris W.
Badpuppy 08-10-2019 11:14 AM
Best get rid of it and repair the reason it was added in the first place. At least untangle the snarl around the moving control pawls and bundle the wires securely out of the way.
SSsssteamer 08-10-2019 12:29 PM
Worth noting is that it looks like the wire used with the relay was a smaller gauge for 12 volt circuits. Using a heavier gauge that is correct for 6 volts will allow more amps to be carried and with more amperes, it will give brighter headlights.
Ernie Vitucci 08-10-2019 06:06 PM
If you have the skills or can find help at the closest Model 'A' club, then return things to stock. The drawings, parts and wiring harness are available from all of the Model 'A' suppliers...Ernie in Arizona
Tom Wesenberg 08-11-2019 10:06 AM
I agree with Ernie, and the wiring isn't too expensive.
Don't eat out a few times, and it's paid for.
DHZIEMAN 08-16-2019 09:39 AM
Need to start tracing wires and getting a voltmeter on them with lights on and off and horn blowing and such! It appears a relay switch was put in place due to some other problem of just someone with nothing better to do. I prefer original wiring and making it work rather than adding relays that can fail. (and based on it's appearance, trying to find a replacement!)
Ernie Vitucci 08-16-2019 07:06 PM
That system reminds me of the south end of a north bound horse! Poor Horse! Ernie in Arizona
