The Ford Barn
-   -   Cabin Fan (https://www.fordbarn.com/forum/showthread.php?t=266777)
Bruce of MN 07-24-2019 02:22 PM
Cabin Fan
When my Dad had my '31 Coupe as a cheap second car in 1953, I remember that it had a rubber-bladed fan mounted up high on the right side of the windshield. When I bought the car back from a cousin in 2009 or so, the fan was gone and I have looked for some modern replacement. This may do the job: https://www.bedbathandbeyond.com/sto...eyword=fan-usb
USB voltage is 5Vdc, so our 6Vdc shouldn't abuse it too much. I got one with a 20% coupon, so I have $8.41 invested! I've soldered on a 2 pole trailer connector and the red fan wire is even positive, so the color code matches. I need to connect to the terminal box and a ground screw and figure out how to hang it yet.
https://www.fordbarn.com/forum/pictu...996099&thumb=1
https://www.fordbarn.com/forum/album...ictureid=41842
Charlie Stephens 07-24-2019 03:29 PM
Re: Cabin Fan
1 Attachment(s)
I am sure you know that at least some of the originals hung on the steering column.
Charlie Stephens
Bruce of MN 07-24-2019 03:52 PM
Re: Cabin Fan
To tell the truth, no, but it makes a lot of sense. Maybe that will inspire some thoughts on a similar mount.
Forddan 07-24-2019 08:13 PM
Re: Cabin Fan
Mine came with the car. I am the second owner after it restoration so I do not have idea if this fan is time period. Neither i know if the attachment is an original accessory. Nevertheless looks pretty old.
Works very well and if you zoom the picture you can see how it is attached.
http://i1106.photobucket.com/albums/...psvg44deya.jpg
BTW... it is a 1929 Tudor.
rfitzpatrick 07-25-2019 07:06 AM
Re: Cabin Fan
Is that a Radio I see just right side steering column?
Neat
Kurt in NJ 07-25-2019 08:44 AM
Re: Cabin Fan
there are also rubber bladed vacuum operated fans ---they moved a little air, but not a breeze
Forddan 07-26-2019 10:52 AM
Re: Cabin Fan
Neat
Yes it is.... Open this posting:
https://www.fordbarn.com/forum/showp...1&postcount=11
jhowes 07-26-2019 11:16 AM
Re: Cabin Fan
Forddan; I have a rubber bladed fan but the mounting is puzzling to me. Did you have to drill holes in your dash rail to mount it? My dad had one in his 33 Chevy but he used it for the defrosting action. Mine has a column mount but there is not enough room for it in the Model A. It hits the steering wheel. Jack
Bruce of MN 07-27-2019 09:31 AM
Re: Cabin Fan
My Grand Experiment is over. :( The 6V seems to have burnt out the 5V motor, since the motor leads show open circuit.
Railcarmover 07-27-2019 09:52 AM
Re: Cabin Fan
110V AC is not 6v DC :)..
Good news,they make solar charged 6v DC fans..Im sure if you wired it direct you would be fine ..
http://suratexim.com/Product-desc/6-Volt-DC-Fan.aspx
katy 07-27-2019 10:18 AM
Re: Cabin Fan
My Grand Experiment is over. The 6V seems to have burnt out the 5V motor, since the motor leads show open circuit.
Shoulda used a 7805 to power it.
Forddan 07-27-2019 11:44 AM
Re: Cabin Fan
Hi Jack
Unfortunately the job was done by who restored the car ~14 years ago. Since then I am the second owner and do not know how to contact the first one, who restored the car.
Nevertheless, at my return home tomorrow I will take a closer look to see if all the holes were drilled or not.
I am new in model A, but from pictures of other cars (1929 Tudor) I will bet they were drilled.
I will report back with an answer.
Daniel
P.S. : I live in MA and last week we had the hottest week of this summer 80-90 F. There was no need to use the fan. With the windshield open driving the car at ~25-30 miles/hour was very comfortable. I only feel how warm it was at the traffic lights stops.
5lugnuts 07-27-2019 12:11 PM
Re: Cabin Fan
A 12 volt neg ground cell phone car plug reduces 12 or 6 volts to 5 volts. Just be careful to wire the ground as positive. I run my phone and GPS off of a Model A 6v battery this way with no problems.
Bruce of MN 07-27-2019 03:21 PM
Re: Cabin Fan
What is a 7805?
katy 07-27-2019 04:16 PM
Re: Cabin Fan
7805 is an electronic voltage regulator: https://en.wikipedia.org/wiki/78xx
taffrail 07-27-2019 10:43 PM
Re: Cabin Fan
1 Attachment(s)
How about vacuum powered, works as good as the wipers!
Tom Wesenberg 07-28-2019 07:05 PM
Re: Cabin Fan
That bad, huh?
Forddan 07-28-2019 09:31 PM
Re: Cabin Fan
Jack, I am back at home. Yes, holes were drilled.
Best
Daniel
taffrail 07-28-2019 10:33 PM
Re: Cabin Fan
Don't drill any more holes, mine was a column mount. Get rid of the strap and run a round head 1/4-20 through the center hole in the dash panel.
jhowes 07-29-2019 07:30 AM
Re: Cabin Fan
taffral; I m a little slow so can you post pictures that will show me what you're doing? Jack
