28 original model A Ford front frame crossmember City:
Lakeville
State:
MN
Price:
125
5 Attachment(s)
For sale, an original Ford hard mount front crossmember. This style was used most of 1928. Many of these crossmembers were modified per Ford’s instruction to cut off the top part of the crossmember, so an uncut crossmember is rare. The crossmember has several holes that need to be welded shut, but the crossmember is in good condition. The part has little or no rust pitting. There are a couple small cracks where the corners are that can’t be seen when installed or could be weld up if desired. The crossmember is fairly heavy, so shipping would depend on how far from the Twin Cities, MN it has to travel.
$125.00 plus shipping |
Re: 28 original model A Ford front frame crossmember ttt
Re: 28 original model A Ford front frame crossmember Sold
