The Ford Barn
-   -   Transmission question from a novice (https://www.fordbarn.com/forum/showthread.php?t=264989)
gtdohn 06-16-2019 02:27 PM
What's a hogsring? Supposedly it goes between the transmission and the engine. Is it just another name for bellhousing? and would it be different between a 6 and 8 cylinder flathead in 1948 F1?
cas3 06-16-2019 02:53 PM
Re: Transmission question from a novice
yes,its the bell housing for the late flatheads, and yes, the 6 cyl. is different. go to vanpelts sales and look at the pictures
gtdohn 06-16-2019 02:58 PM
I went to Vanpelt sales but I couldn't find what category to look at.
Bob C 06-16-2019 03:00 PM
1 Attachment(s)
Do you mean hogshead??
gtdohn 06-16-2019 03:04 PM
Maybe.
gtdohn 06-16-2019 03:16 PM
If I want to put a 1939 3 speed, that was built for a flathead 8 cylinder, behind my 1948 6 cylinder, which one would I need to use?
Mac VP 06-16-2019 03:35 PM
If your flathead six is the 1941-47 G series, you have to use the gearbox case made for this motor. If you have the 1948-51 H series flathead six, you would need the stamped steel bell housing made just for this engine, and then bolt up the regular top loader or side loader 3 speed gearbox to it.
gtdohn 06-16-2019 05:00 PM
Where might I find the stamped steel bell housing for a 1948 6 cylinder. The 1939 3 speed has already been converted to open driveshaft, but it has the bell housing for a V8.
cas3 06-16-2019 06:25 PM
i have a bell for you, but i do not have the starter plate. wonder if any others will work?
gtdohn 06-16-2019 10:42 PM
I'm really confused after looking at the 1939 3 speed again. The bellhousing is an integral part of the transmisson casing and can't be separated from the rest. So how can it be changed?
deuce lover 06-17-2019 01:56 AM
1 Attachment(s)
Maybe this will help.Here is a pic from the Green Bible. cas3 has your bellhousing.You can see the starter plate part number 7007. Your trans then should bolt up as Mac VP said.
Terry,OH 06-17-2019 06:41 AM
For the Ford the entire bell housing is in a few pieces. Part that covers the rear of the pressure plate and contains the throwout bearing assembly is on the transmission and does not get changed. The cover for the side of the pressure plate and the flywheel and the back of the transmission is a separate piece that you need to change. That cover has yet another piece that mounts the starter motor see the diagram above, look for part numbers 6392 and 7007
Mike51Merc 06-17-2019 07:22 AM
Hog rings hold your upholstery on the seat frames.
Hogs head is the transmission bellhousing part.
gtdohn 06-17-2019 09:53 AM
Thanks everybody, this flathead stuff is all new to me. Now give me a 1965 Mustang and I can take it apart and reassemble it blindfolded. With all this help, I am learning. It's just so different but still familiar in a small way.
cas3 06-17-2019 07:27 PM
you could check with fred at south side obsolete for a starter plate, barnfind 08 is his handle here
nickthebandit 06-19-2019 01:12 PM
the Hogs Head adapter is used to fit the truck 4-speed transmission to the bell-housing.
