The Ford Barn
-   -   sears engine analyzer 12v pos. grnd. hookup (https://www.fordbarn.com/forum/showthread.php?t=264906)
artron9 06-14-2019 06:50 PM
I have an old Sears engine analyzer which is 12volts. I want to check rpm and dwell on my 52 pos.grnd 6volt Ford v8. How should I connect the red, black and green wires. Ive been getting different suggestions? I believe an external 12 volt battery should be used during this setup? What do you think?
c-gor 06-16-2019 01:26 PM
Re: sears engine analyzer 12v pos. grnd. hookup
Use a 9 volt battery Hook up the analyzer leads + to + - to - Place the inductive pick up over #1 Plug Should work for RPM
Re dwell the analyzer will not work Set to TDC and use timing light
artron9 06-17-2019 09:52 PM
Thank you c-gor!
