The Ford Barn
-   -   Electrical Problem? (https://www.fordbarn.com/forum/showthread.php?t=264720)
chrs1961815 06-11-2019 11:01 AM
Electrical Problem?
I went to start the A Sunday and it would not start. So I have checked the battery connections and cleaned them up, still nothing. Cleaned the ground, nope. Checked the disconnect switch I have by bypassing them and still nothing. Cleaned the starter switch wires, still nothing. The battery is not dead, I hooked it up to my charger and it was pretty much full. What is the problem? We finally have some nice weather out here!
wmws 06-11-2019 11:36 AM
Re: Electrical Problem?
By not start I assume you mean won't crank. You have checked all the important connections. So I would check the switch contact on top of the starter. Or possibly your starter pinion is jammed on the ring gear.
chrs1961815 06-11-2019 11:38 AM
Let me elaborate on my post: nothing works on the car electrically.
Farrell In Vancouver 06-11-2019 11:47 AM
How old is the Battery.
How much voltage is the Battery holding?
Patrick L. 06-11-2019 11:53 AM
If nothing is working then I guess its time to get out the test light or volt meter. Start at the beginning and just keep checking for voltage. Since nothing is working the problem shouldn't be far from the battery or starter terminal.
chrs1961815 06-11-2019 12:02 PM
The battery was in the car when I bought it. The date on it was April 2018. Time to grab the volt meter.
chrs1961815 06-11-2019 01:43 PM
I fixed it! Traced the problem to the terminal box where one of the wires slipped out of the flag terminal. Temporarily fixed it until I can do it right.
Patrick L. 06-11-2019 01:51 PM
Well, wires slipping out of their terminals is not a good thing.
chrs1961815 06-11-2019 02:25 PM
Especially since the car was rewired with new wire last fall...
1931 flamingo 06-11-2019 02:38 PM
Thanks for the update ! !
Paul in CT
Purdy Swoft 06-11-2019 03:10 PM
I usually solder the ends of the wires so they can't come off .
jm29henry 06-11-2019 05:30 PM
could someone please help me understand ? if the battery positive cable goes to the frame and the negative cable goes to the starter,how does a wire on the terminal box keep it from turning over. i can see that it would keep it from firing up but i believe it should have CRANKED OVER!!!
Patrick L. 06-11-2019 05:33 PM
Me too. I guess we have a lot of old to go along with our fashion.:D
Patrick L. 06-11-2019 05:36 PM
I had the same question also, but, he said its fixed, so,,,,,
Life has its wonderments.
chrs1961815 06-11-2019 09:15 PM
I never said I tried to crank it!
30 Closed Cab PU 06-12-2019 08:53 AM
Previous post - "Let me elaborate on my post: nothing works on the car electrically.".
We assumed that this statement also meant the Starter was not working.:)
katy 06-12-2019 09:40 AM
Does the car have the foot push starter switch? Or does it have/use a solenoid?
FWIW, a Model A engine can be cranked over w/the starter or by using the hand crank.
Patrick L. 06-12-2019 02:09 PM
I guess that is what happens when we assume things.
J Franklin 06-12-2019 02:19 PM
How was the car supposed to start if it is not cranked by the starter or hand?
Benson 06-12-2019 05:48 PM
Huh?
