The Ford Barn
-   -   Rear Wheels (https://www.fordbarn.com/forum/showthread.php?t=263586)
1930deluxe 05-18-2019 09:27 PM
Rear Wheels
When up on blocks with car running and in gear should both wheels turn at the same time or is just one the drive wheel?
SSsssteamer 05-18-2019 09:50 PM
Re: Rear Wheels
On jack stands, when the clutch is first released, usually both rear wheels turn. After they get up to the speed of the engine, the wheel with the most drag will slow down to a near stop while the other wheel speeds up. Very rarely will both rear wheels continue to spin at the same speed continually while in gear and the motor is running.
Patrick L. 05-19-2019 06:21 AM
Re: Rear Wheels
These, as most, use a standard differential rather than any form of limited-slip or posi-traction. In other words only one wheel will drive and its the wheel with the least traction.
