Need photo of the first Brake Rod Spring Bracket ---Rear Would anyone have a good photo of the first Brake Rod Spring Bracket---Rear (1928 type) for which I may use in an article?
If so...PLEASE send it to my email address [email protected] Thanks. Pluck |
Re: Need photo of the first Brake Rod Spring Bracket ---Rear Plug, I have much pictures. What spring exactly do you mean, please? Anti shatter old style?
Re: Need photo of the first Brake Rod Spring Bracket ---Rear It is the first Brake Rod Spring Bracket---Rear (1928 type) that is welded to the Rear Radius Rods.
Pluck |
Re: Need photo of the first Brake Rod Spring Bracket ---Rear 1 Attachment(s)
It is heavy/not light for me, exactly know the brake spring that you mean. On sight in this picture?
Re: Need photo of the first Brake Rod Spring Bracket ---Rear Steve,
Pic's sent, let me know if that's what you wanted. Regards Bill |
Re: Need photo of the first Brake Rod Spring Bracket ---Rear Quote:
Thanks. Pluck |
believe don turley posted these in the past ... same as mine. i can post pix of mine tomorroe
Re: Need photo of the first Brake Rod Spring Bracket ---Rear Steve, as above picture, I have a complete rear end here with them on, may be able to do close up pic , Regards Derek
Re: Need photo of the first Brake Rod Spring Bracket ---Rear Thanks boys....I got a good one from Jim Mason.
Pluck |
