41 woodie dash install Quite a wrestling match to install the dash on my 41 woodie. I had to take all the steering column bolts to frame loose to get the column to dash bolts fitting at the same time as the bolts on the lower corners. Oh and had to loosen the hood latch cable as well. Did get the cable installed after making 4 fittings to hold it based on pictures a Barner posted of his. The wood graining turned out nice, used the kit from the guy in Florida with graining plate and rollers.
https://flic.kr/p/25atiMn |
Re: 41 woodie dash install Tex, how close are you to completion?
Re: 41 woodie dash install Quote:
Can run/drive today if I wanted. |
