The Ford Barn
-   -   LED headlight bulbs (https://www.fordbarn.com/forum/showthread.php?t=262711)
Tom in SW VA 05-01-2019 06:51 AM
LED headlight bulbs
Are LED headlight bulbs available for a 37 Ford? Any advice
or recommendations will be appreciated.
Thanking you in advance.
4dFord/SC 05-01-2019 09:07 AM
Re: LED headlight bulbs
Here's a recent thread on the subject: https://www.fordbarn.com/forum/showt...headlight+bulb
Tom in SW VA 05-03-2019 09:19 AM
Who can tell me which LED headlight bulb to purchase for my 37 Ford?
deuce lover 05-03-2019 09:36 AM
If you click on the link the APF bulb which has the flange might be correct .Email them and ask.
https://redirect.viglink.com/?format...bulbs-shop.php
Kurt in NJ 05-03-2019 11:17 AM
None of the led bulbs made now will focus properly with original reflector/lense
cajunfirehawk 05-03-2019 11:43 AM
My 36 w/repop reflectors, w/led HL bulbs, and led turn signal bulbs. I never planned to drive my car at night but these were just in case I got caught out late, so I cant say how the beam is on these but they are low current draw and very bright in my shop, fwiw, YMMV
https://youtu.be/gZb51U1mTaU
Karl 05-04-2019 12:20 AM
Correct
Although they appear to throw out lots of light it is unfocused light and doesn't fall where it should. This is not anecdotal -unlike most of what is written about LED bulbs here and elsewhere . I have checked various LED bulbs in my original 1934 headlights with a correctly calibrated headlight machine (used to check headlights for a legally required 6 monthly vehicle safety check in my country) which confirms that they don't focus correctly.
philipswanson 05-04-2019 09:41 AM
Yea and the ones I have seen are all 12v and not 6v negative ground.
