1937 ford chassis-vs 1940 will a 40 coupe body fit on a 37 chassis wo any mods?
thanks! |
Re: 1937 ford chassis-vs 1940 yes, 1935 to,40 and 1941 pick up , will work ,
Re: 1937 ford chassis-vs 1940 You will have to fit the 40 brake pedals, the hole is different. The radiator mounting brackets will need changed to the 40 style.
If it's a 37 v860 chassis a couple other things need changed. In general, it will fit |
Re: 1937 ford chassis-vs 1940 Front cross member and the centre box section will need to be changed out as well.
Re: 1937 ford chassis-vs 1940 man you guys are good!
only posted this about an hour ago. yes it is the 60hp............. |
Re: 1937 ford chassis-vs 1940 Most often, back in the day that switch went the other way, guys put a 37 body on a 40 chassis to get hydraulic brakes.
Re: 1937 ford chassis-vs 1940 Your DMV may want to register your car as a 1937 based on the serial number when you change the frame. Whatever you do be sure to keep them happy.
Charlie Stephens |
no problem in NJ- all good. we have no inspection on antiques. |
