NOS Airtex Fuel Pump - Worth it? 1 Attachment(s)
I came across this today on kijiji (Craig's List for Canada)
Was wondering if this is anything or worth it. |
Re: NOS Airdex Fuel Pump - Worth it? 1 Attachment(s)
Second pic.
Last pic.
Re: NOS Airtex Fuel Pump - Worth it? Well, Airtex is still in business and the diaphragm is guaranteed for 50,000 miles, so why not?:)
Re: NOS Airtex Fuel Pump - Worth it? Modern gas will probably dissolve old diaphragm.
Re: NOS Airtex Fuel Pump - Worth it? Yep the diaphragm will be a licorice gum drop before your eyes once any kind of today's gas gets to it. Check the location of the ports. I do like these pumps for multi carb setups
they have a good look and the valves are always wet which helps self priming. Charlie ny |
Re: NOS Airtex Fuel Pump - Worth it? I bought one of those, but put a new kit in it to replace the old dried out rubber
Re: NOS Airtex Fuel Pump - Worth it? That pump is known as "the bus pump", a high volume pump used on Ford rear engine city buses starting in 1944.
Favored by hot rodders during the flatheads prime days. It's an AC pump & diaphragms are available. |
Re: NOS Airtex Fuel Pump - Worth it? Quote:
150 can, wow. Last (and only) pump I bought was a old 'rebuilt' one that had been stored many years. Because it was old (but still looked clean and fresh), the seller asked 5 dollars (us), and cautioned that it would probably have 'old-diaphragm' problems. I put in a new, modern diaphragm, and it has been running for the last few years. I must be old, and out of touch, or, very lucky at a local swap meet. |
Re: NOS Airtex Fuel Pump - Worth it? Yep, spent only CAN$100 for my flathead, but I'm many many times that now just in parts.
Re: NOS Airtex Fuel Pump - Worth it? I have an older mechanical pump for mine with a glass sediment bowl, but I have removed the pushrod and I will run a hidden electric pump and regulator to control the pressure. I will have the fuel come from the hidden pump and reg up and through the pump just for show.
Re: NOS Airtex Fuel Pump - Worth it? Today, most people have never heard of the "bus pumps". They are a nice vintage accessory for anyone building an old-time hot rod. I believe they are identified by the 10 screws holding the diaphragm. I have two new bus pumps stashed away. One is an old Airtex box with the same part number as this one, It says on the box Ford Spl, 1943-1944.
We only used Airtex pumps at the phone company and they always lasted as long as the OEM pumps. |
