The Ford Barn
-   -   What is the best head bolt thread sealer ? (https://www.fordbarn.com/forum/showthread.php?t=261280)
19Fordy 04-02-2019 11:50 AM
Years ago I used FEL PRO Gray Bolt Prep # GRA2. It was the best. Now it's no longer being made. Contacted Permatex and they recommended ULTRA GREY TORQUE GASKET MAKER # 82194.
https://www.autozone.com/sealants-gl...ker/306563_0_0
I am dubious.
What do you folks recommend for thread sealer flathead head bolts?
Thank you. JIM
RalphM 04-02-2019 04:01 PM
Re: What is the best head bolt thread sealer ?
1 Attachment(s)
Aviation permatex
philipswanson 04-02-2019 04:33 PM
Originally Posted by RalphM (Post 1743081)
Aviation permatex
Ralph,
Agreed! That's the best!
See you in June....
Phil
flatjack9 04-02-2019 05:23 PM
A good grade of teflon pipe dope is what I have used for years.
Talkwrench 04-02-2019 07:02 PM
Brian put me on to Loctite 577. lookin' good so far..
KiWinUS 04-02-2019 07:26 PM
3M 8001 weatherstrip cement
Used for many years on hundreds of engines where bolt/stud goes into water jacket from stock to full blown race engines. Never a leak! In the 80-90's it was the standard in NASCAR to use on valve cover gaskets so you would never have a leak.
Cheers
Tony
Dave Castle 04-02-2019 08:05 PM
Permatex high performance Thread Sealant # 56521.
Tinker 04-03-2019 12:11 AM
Is some anti-seize out of question here for non race motors? Not a true sealer but makes the bolts come out and gumms up the water flow. I don't know though.
flatheadmurre 04-03-2019 12:31 AM
Jess you want sealing and threadlocking...with anti-seize the studs will come out any time you want to remove the head...
I use loctite pipethread sealer...has a fixed torque rate...meaning it holds the stud but not in an absolute irongrip if you want to remove it.
Tinker 04-03-2019 12:42 AM
Hey Murre, thank you. I at least know, anti-seize changes torque values. Just curious, something like perm gen1# indianhead or anti-seize is bad. Just curious.
flatheadmurre 04-03-2019 05:47 AM
Permatex nr1 is hard setting so works great in that aplication.
