29 ccpu door post to floor rail bolt up On the 29 ccpu, how did ford connect the door wood post to the floor pan rail, was the bolthead on the wood side or the floor rail side, and how did they address the fact that on the floor rail on a 30* angle.
thanks nick c |
Re: 29 ccpu door post to floor rail bolt up |
Re: 29 ccpu door post to floor rail bolt up I looked but did not see the bolt up.
thanks anyway |
Re: 29 ccpu door post to floor rail bolt up It's in there,....look at #41
Re: 29 ccpu door post to floor rail bolt up Thanks, I see it now, does of the suppliers sell them, does anyone know the name of the part or have a good picture, I sure I could make 2 of them.
thanks |
Re: 29 ccpu door post to floor rail bolt up 3 Attachment(s)
Nick, this may be the piece you are looking for. There are carriage bolts that hold the wood to this bracket. The head of the bolts is toward the outside of the cab, the nut is on the inside of the cab.
Brattons https://www.brattons.com/28-m30-p-u-...tom-brace.html You could probably get repro's or originals from Berts in Denver. Here are some photos - |
Re: 29 ccpu door post to floor rail bolt up That's it, Im sure I had them when I dismantled the entire truck 9 yrs ago but cant find them, the second bolt is below and is accessed through the slotted hole in seat riser.
thanks |
