The Ford Barn
-   -   New gas tank cleaning (https://www.fordbarn.com/forum/showthread.php?t=259689)
ford35lh 02-25-2019 12:38 AM
Got a new tank for my 66' and was wondering if it needs to
be cleaned internally . What works ???
FortyNiner 02-25-2019 05:16 AM
Re: New gas tank cleaning
I would just use a small amount of ethanol gas and slosh it around a bit.
rotorwrench 02-25-2019 01:02 PM
The fuel is likely less cost than most other solvents. A person could use soap & water but I worry too much about corrosion unless is it a plastic tank. A person has to dry it out if you use water. A new tank should have been cleaned by the manufacturer but you never know now days.
