The Ford Barn
-   Late V8 (https://www.fordbarn.com/forum/forumdisplay.php?f=10)
-   -   Overdrive Solenoid , relay , governor 6 Volt Ford (https://www.fordbarn.com/forum/showthread.php?t=258943)
steve fritz 02-08-2019 10:36 PM
City: Onalaska
State: Wi
Price: 225.00
1 Attachment(s)
Nice used overdrive solenoid , relay and governor for 6 volt system Ford 49-55.
Bench tested all good. $225 for all.
Make offer if you need just one or two parts of the three.
[email protected]
608-738-1861 or PM me on the Ford Barn message system.
steve fritz 02-20-2019 11:27 AM
Re: Overdrive Solenoid , relay , governor 6 Volt Ford
I have two solenoids and three relays , and one governor left to sell.
Thanks to all those that have bought these from me. Have been told that same parts work fine on Studebaker , Packard, Plymouth , maybe others.....using the BW transmissions. 6 Volt system
Steve
steve fritz 03-15-2020 01:22 PM
I sold all the solenoids and governors , but still have a couple of the firewall mounted relays. Two styles , one for 49 and 50 Ford the other is for 51 to 55 Fords. Only difference is the mounting bracket on the can. Older models are right angle and the later models are flat mounting tab.
Both are original 6 volts and bench tested good.
$90 each.
Steve
