The Ford Barn
-   -   12 volts (https://www.fordbarn.com/forum/showthread.php?t=258888)
swoopNZ 02-07-2019 09:08 PM
12 volts
A friend is going to install 12 volt headlamps in his 39 coupe.
He wants to know will he have to change everything else - eg:
generator to alternator, interior bulbs, radio, tail lamp bulbs etc.
Any Fords I have had in the past have always retained the 6 volt system.
Thanks in advance.
Chris.NZ.
JSeery 02-07-2019 09:10 PM
Re: 12 volts
This appears to be a second post with the same question. It would be much better to keep this in one thread (the original one).
swoopNZ 02-07-2019 10:07 PM
Re: 12 volts
You are right - for some reason it didn't show up the first time ???
Red98 02-09-2019 10:50 PM
Re: 12 volts
Seems to happen when you interrupt writing a post for dinner.
