The Ford Barn
-   -   speedo gear (https://www.fordbarn.com/forum/showthread.php?t=258443)
xmarine 01-30-2019 10:03 AM
speedo gear
Speedo reads about 12mph higher then GPS so my question is simply would I change speedo gear to more teeth or less teeth
katy 01-30-2019 10:17 AM
Re: speedo gear
More.
xmarine 01-30-2019 12:02 PM
Re: speedo gear
Thank you
Kurt in NJ 01-30-2019 01:13 PM
Re: speedo gear
How is the odometer-- if that reads correctly the problem is in the speedometer, not the gearing la
GRutter 01-30-2019 10:59 PM
Re: speedo gear
If you let us know your wheel size and rear-end ratio we can tell you what your speedometer gear "should be". Then if it doesn't read correctly the problem would be in the speedo not the gearing.
For example, a 30-31 with 19" wheels and 3.78 Rear (Standard) would use an 18 tooth driven gear in the speedo turtle
