The Ford Barn
-   -   Radiator cap/grillshell (https://www.fordbarn.com/forum/showthread.php?t=258203)
Marty_in_Mesa 01-26-2019 07:09 AM
I mounted my radiator in my 29 Tudor, on it's padded spring mounts. I mounted the grill she'll to the radiator using the tabs on the radiator.
The problem is the filler neck doesn't seem to come through the grill shell enough to allow me to put the cap on. The filler neck mouth barely protrudes through the grill shell.
I don't know the history of the car. The grill shell was just flopping around on the radiator unsecured when I got it. Any thoughts or advice appreciated. Google photo album of the car can be found here: https://photos.app.goo.gl/9dgiEq4TPAzhtGBj9
Thanks in advance for any thoughts/advice.
Marty
Sent from my Moto G (5) Plus using Tapatalk
jhowes 01-26-2019 09:14 AM
Re: Radiator cap/grillshell
I'm no expert but is that a 28?? It seems to have a red steering wheel and a 7 tooth steering box. This doesn't help with your problem but just wondering. Jack
Joop 01-26-2019 10:03 AM
Hi Marty
Nice project.
Looks like that is a new aftermarket shell and there are a lot of fitting problems involved with those I am told.
Contact Sammie at Arizona A's for more info
WHN 01-26-2019 10:05 AM
Where did you buy the radiator?
I have seen this problem before.
Gary Karr 01-26-2019 12:07 PM
Your issue most likely is a combination of an aftermarket radiator and a reproduction shell.
Purdy Swoft 01-26-2019 12:21 PM
I agree
Marty_in_Mesa 01-26-2019 08:16 PM
I got the car as you see it.
Marty_in_Mesa 01-26-2019 08:17 PM
Ah, that's too bad. I wonder if a radiator shop could extend the neck on the radiator. Who makes a good reproduction shell?
Purdy Swoft 01-26-2019 08:55 PM
There was a similar thread not long ago. I've had the same problem with the repro 28-29 radiator shells . I have ground down the height of the neck of the shell a bit and then ground down the bottom of the repro radiator caps for more clearance . This will allow the cap to meet the threads and tighten down . It will take trial and error to determine how much material must be removed . I think that this method works better than removing and shimming up the radiator neck . care must be taken when grinding . I used a nine inch air grinder. It would be much safer to use a long file but will take a lot more time .
Marty_in_Mesa 01-26-2019 09:19 PM
Thanks for the information. I may try this.
Though there isn't much of the radiator neck sticking up at all.
denniskliesen 01-26-2019 11:59 PM
A picture of the backside if the radiator is needed with pictures of the brackets and upper and lower neck.
Gil Sissons 01-27-2019 12:17 PM
Marty you got your answer from Joop above....
And he is in your neck of the country.
Contact Sammy at Arizona Model A.
Very knowledgeable..... great supply of new & used parts.
Gil. NoCal
Joop 01-27-2019 06:43 PM
Call Sammy on tuesday as he is in Turlock right now
480-782-0266
Marty_in_Mesa 01-27-2019 10:06 PM
Dennis, I'll try and post some pictures of the back side tomorrow.
Marty_in_Mesa 01-27-2019 10:07 PM
480-782-0266
Thanks, I've met Sammy! Neat to know they are close and have so much inventory!
Marty_in_Mesa 01-28-2019 03:00 PM
I added some pictures to my album of the radiator/grill shell showing the inlets and outlets as requested.
Thanks again guys,
Marty
