1933 fuel/Temp gage problem Gentlemen...
I am working on an stock 1933 5 Window Coupe which has an original fuel and engine temp gage. The gage housing was so rusted it fell a part when I removed the two mounting nuts. The owner would like the find some parts to replace the damaged housing or a replacement unit. Currently sticking a dummy gage unit and install a modern gas gage and engine temp gage is not an option as of now. Any help is very much appreciated... Joebeeker |
Re: 1933 fuel/Temp gage problem The fuel and temperature gauge is an approved accessory and hence not standard.
The original would have been just a fuel gauge . The fuel gauge is easier to find they come up on Ebay frequently . The dual gauge appears there less commonly and goes for much bigger bucks. If it was my car i would install the standard fuel gauge and replace the radiator hose with one not holed for the temperature probe and wait for a dual gauge to come up -They never had a temperature gauge originally and will do fine without one for a while -Karl |
| All times are GMT -5. The time now is 05:55 AM. |
