The Ford Barn
-   -   Brake question (https://www.fordbarn.com/forum/showthread.php?t=255835)
mh_merc 12-08-2018 11:18 PM
Brake question
'47 Merc; stock drum brakes with a Hydrovac booster; NEW master cyl., wheel cyls., rubber hoses, shoes.
PROBLEM: Pedal is very low when motor is cold, but gets higher and firmer as it warms up. Does this sound like a booster issue (it's the only thing that hasn't been touched)?
Kurt in NJ 12-09-2018 02:02 AM
Re: Brake question
You need to check that the engine vacuum to the booster the same or changes as the engine warms up ---if it stays the same look closewr at the booster, if the vacuum gets lower as the engine warms up look for engine problem---lower vacuum will make the pedal higher and firmer
mh_merc 12-09-2018 10:48 PM
Re: Brake question
Thanks Kurt - it's probably the booster; the engine is a good-running small-block with fewer than 30K mi. on it.
Flathead Fever 12-10-2018 04:01 PM
Re: Brake question
We had Suburban's in our fleet at work. When you first started them, when the choke was on fast idle you had no vacuum assist from the booster. If you put them in gear you could barely stop them until the engine warmed up. It was scary. I have no idea how GM would have manufactured them this way?
If its like the cars I worked on there should be a vacuum check valve on the booster. If its holding vacuum you should have assistance when its cold. If it has one, shut off the engine and wait awhile. Then disconnect the check valve from the booster and see if it sounds like there was vacuum being held in the booster. If it does not have one maybe it is suppose to? If there is no vacuum then either the check valve is bad or the booster has a small leak.
