Panel Board 2 Attachment(s)
I am cutting the panel board for my 1930 Tudor sedan. My question is how far does the headliner come down the sides? I cut the corner the same size as the one that was removed but it leaves a gap at the top near the side window. Will the headliner cover this area? See photos
Re: Panel Board I would think if you cut it the same as removed one then it should work.
Re: Panel Board MMMM your top edge of panel board needs to angle up just to the top of the tack strip.
Re: Panel Board If I am remembering correctly, the top was not a straight cut. The ones removed were not factory so I cannot attest to the accuracy, but they had a curve and were taller at the side than the back. 18" tall at the side window and about 17" at the back window. It was not a gradual straight cut though. From the side window it goes straight for about 9" then curves down and straightens at the back window. I am not sure that makes any sense. I wish I had kept the pattern but I am sure someone has it out there.
