The Ford Barn
-   -   1929 Model A coupe top (https://www.fordbarn.com/forum/showthread.php?t=255547)
joetx 12-01-2018 11:50 PM
Not familiar with a '28-9 coupe. Does the top on a '29 coupe separate from the lower rear quarter panel section or is it a one piece as the '30-1 coupe? Thanks, Joe.
Steve Plucker 12-02-2018 09:25 AM
Re: 1929 Model A coupe top
Joe,
There were four types of "coupes" for 28-29...Standard Coupe, Special Coupe, Business Coupe and Sport Coupe...for which type of "coupe" are you reffering to?
Pluck
joetx 12-02-2018 11:08 AM
Originally Posted by Steve Plucker (Post 1701572)
Joe,
Pluck
I don't know what this body is. It has a flange around from door to door. I've seen pictures of the Business and Sport coupe and I think these had a canvas top. I'm probably referring to the Standard and Special coupe with the metal top. What I'm asking, is whether this metal top is removable leaving that flange where it would have bolted on.
https://photos.app.goo.gl/5ZJoNcoKgzrK9PeV9
https://www.dropbox.com/s/t4jeq1smsg...coupe.jpg?dl=0
joetx 12-02-2018 11:18 AM
[IMG]https://www.fordbarn.com/forum/pictu...ictureid=41003[/IMG]Body picture.
kbinde2 12-02-2018 03:06 PM
Joetx.. If you use the "search" tab at the heading on the forum page, type the body style you want to look at (eg. Special, Sport, etc.) and tons of information will be available to shift through. I think you're asking the question about the "belt-rail" section, and how the top is formed to the body panels. My avatar shows a '29 Special Coupe.. kb
joetx 12-02-2018 06:18 PM
I have searched and I'm not finding the info I need. Thanks. My question is whether the top separates from the quarter panels or is it one piece. I know that in the '30-1 it does not separate and is a one piece. Reason I ask, is because I was told that the picture above is of a coupe and needed the top put back on? I didn't know the '29 standard coupe separated here and I still don't know....
https://www.fordbarn.com/forum/pictu...ictureid=41015
SteveB31 12-02-2018 07:45 PM
Yes, the upper quarters and lower quarters as well as the center panel all unbolt on the 1928-1929 coupes. On 1930-31 coupe, only the cente panel unbolt- the quarters are each all one piece
joetx 12-02-2018 07:54 PM
Thanks, that's what I needed to know. Appreciate it. Joe.
Gary Karr 12-03-2018 12:47 PM
In addition to the nuts and bolts between the upper and lower quarters, you will also find some spot welds.
