Another possibly stupid question... so I'll blame it on the dog. Buster wants to know if the axle sticking out of the housing as shown here, should wiggle a bit. Is it just the bearings in the hub that hold it in place?
https://i.imgur.com/fFuL5ob.jpg |
Re: Another possibly stupid question... Yes, only the bearings in the hub locate the axles outer end.
Re: Another possibly stupid question... Looks like the dawg is taking a close look at things. Ask him!:D
Re: Another possibly stupid question... Quote:
Re: Another possibly stupid question... why is this question stupid?
inquiring minds want to know............ |
Re: Another possibly stupid question... Most that don't have a few years model A experience will notice the loose .ness and figure that it is caused by internal wear . the weight of the rear end of the car is carried by the hub bearing and the rear axle housing bearing race . In time the rear axle housing bearing race race will wear on the bottom and can cause problems with rear brake adjustment . If the rear brakes are adjusted with the rear axle on stands , sometimes the brakes can be too tight and drag when the car is taken off the stands . This drag is usually caused by wear in the outer hub bearing and mostly rear axle housing bearing races . This wear causes the brake shoes to get out of center and drag ..
Re: Another possibly stupid question... The only dumb question is the one that does not get asked.
Re: Another possibly stupid question... The Snyder's catalog has a nice exploded view of all the brake and hub parts, but not one of the rear axle, so I had no idea if there was also a bearing in the housing.
Re: Another possibly stupid question... I thought the same thing with my first model A . I figured at the time that I was going to try and get by with it as long as I could .
