The Ford Barn
-   -   49 ford 6 volt positive ground with pertronic ignition (https://www.fordbarn.com/forum/showthread.php?t=255098)
Habusailor 11-21-2018 04:43 PM
This car is really hard to start when the engine is cold. The spark is weak while the starter is engaged but very hot spark once the engine is running. I bought the car with the electronic ignition. I have cleaned the grounds, any ideas from the experts out there?
Sent from my SM-T550 using Tapatalk
Bill OH 11-21-2018 05:00 PM
Re: 49 ford 6 volt positive ground with pertronic ignition
Using a voltmeter, I would check for voltage drop from the battery negative terminal to the starter terminal and from the battery positive to the case on the starter. The tests will show up bad connections, faulty solenoid switch and cables that are designed for 12v. Make sure you have 6v cables. Find a ammeter that will go over the starter cable while cranking to determine the current draw. If all shows good, you might consider an Optima battery - expensive, but has a long life and will give the starter what it requires. Make sure all of your connections are CLEAN AND TIGHT!!!! I am assuming that the starter is in good condition!!??
JSeery 11-21-2018 05:11 PM
Bill pretty much covered it, while you are attempting to start the vehicle the current draw is so large that there is little left over for the ignition.
51 MERC-CT 11-21-2018 05:19 PM
And of course you have eliminated fuel starvation as the source of the problem??
Bill OH 11-21-2018 05:38 PM
Another thought: I use 5W20 Mobil 1. Maybe your oil is to heavy?
Habusailor 11-21-2018 05:49 PM
I think I have issues with current draw. Charlie just rebuilt the carb but I will test fuel pump output and vacuum too. After cranking, choking and pumping in different sequences it seems to be flooded. The car has been sitting for many years so I suspect corrosion on the electrical side. Thanks for all the input, this is why I love this blog.
JSeery 11-21-2018 09:25 PM
I would start by assuring the battery, starter and ground cables are the correct size. It is very common for someone to put a auto parts store cable on these old vehicles and very few of them would carry the correct wire gage. 6v requires about twice the current compared to a 12v system and thus heaver gauge wiring.
Habusailor 11-21-2018 10:24 PM
The solenoid to starter cables are original so the correct size. I did put on a new cable from battery to solenoid that is a 0 or 1. I know it should be 00. First thing I will do is clean more terminals and grounds. I have learned over the years not to overlook the simple stuff and charge into the complex things.
50fordcoupeman 11-21-2018 10:42 PM
Maybe check the air gap in the Pertronix module.
4dFord/SC 11-21-2018 10:51 PM
They may be showing their age.
drolston 11-21-2018 11:11 PM
If there is any green showing on the copper strands entering the connectors, or the copper strands are pinkish, the cable is probably corroded internally and should be replaced, even if it is the proper gauge.
flatheadmurre 11-22-2018 01:55 AM
Check voltage at the battery while cranking to...may be that the battery canīt put out enough amps and then the voltage drops...just saying before you tear the car apart.
WABOOM 11-22-2018 08:08 AM
You use 5w20 in a flathead?
Bill OH 11-22-2018 09:38 AM
Yes, I have used 20W since 1950 in a flathead and never tossed a bearing. Also used it in farm tractors, farm truck(59AB) and combine. And I used it in a 1980 Olds Diesel that ran to 119K when a collision did it in. Bought it by the barrel.
JSeery 11-22-2018 08:06 PM
5w20 is not the same as 20w. The "w" stands for "winter" rating, so the 5w is rated at the winter temperature rating and the 20 at the normal high temp rating.
bullrunmotor 11-22-2018 09:46 PM
My 6 volt pertronix on my crab distributor ran much better when I replaced the copper core wires with silicone and opened up the sparkplug gap another .005 . pertronix is not telling folks to replace the copper ignition wires for higher capacity silicon/carbon sires.
BUBBAS IGNITION 11-22-2018 09:47 PM
Six volt and positive ground can be pretty touchy with electronics, system has to be perfect to work and have NO voltage drops.......especially while cranking......I would suggest changing back to points on this situation ...
tubman 11-22-2018 10:01 PM
Finally! Somebody said it. I've been holding my tongue. Thanks, Bubba!
Habusailor 11-23-2018 08:33 AM
Thanks to all and for sure bubba. My first step will be check cables and contacts, then go back to points and condenser. It's cold in Fargo but I can work in a heated shop but can test in cold temps.
Mike51Merc 11-23-2018 10:26 AM
What coil are you using?
I have a 6V pos gnd Pertronix and had ignition troubles for a long time until I finally got the 0.6 ohm Pertronix ignition coil. Runs great, and sorry Bubba but I'll never go back to points and condensors!
