The Ford Barn
-   -   No Foot Starter (https://www.fordbarn.com/forum/showthread.php?t=254651)
fredski53 11-12-2018 11:47 AM
No Foot Starter
In the latest issue of The Restorer Magazine,there is an advertisement for a push button starter for the Model A. My Victoria has the Ken Davis A/C. The A/C unit blocks the starter button, and makes it difficult to reach the starter button! Has anyone used the No-Foot-Starter? It looks promising! I know it's not what Henry designed, but it would work for me! Thanks, Fred
michael a 11-12-2018 12:31 PM
Re: No Foot Starter
There is two ways you can go with this one way is to wire it up like the later model V8 with a solenoid the other way is that starter adapter that attaches to your spark advance lever it's pretty much a bolt on I will look in the Snyder's catalog and give you a parts number
Sent from my SM-J700T using Tapatalk
Jacksonlll 11-12-2018 12:32 PM
Re: No Foot Starter
Just put in a solenoid then you just push a small button.
michael a 11-12-2018 12:32 PM
Re: No Foot Starter
It's called a Sparky start a one one 384 this is at Snyder's I got mine through eBay a little cheaper
fredski53 11-12-2018 11:41 PM
Re: No Foot Starter
Jack, I was thinking about doing what you suggest . I like this because you can use your exsisting cables! And you don't have to drill a hole in your dash.
Jacksonlll 11-13-2018 06:26 AM
Re: No Foot Starter
You do have to modify your starter post to attach a cable to it. Better have a starter guy do it. Good luck.
jhowes 11-13-2018 08:06 AM
Re: No Foot Starter
I have the one that attaches to the spark lever and it has worked great for years. I put it in because at age 82 I couldn't push the foot starter button any longer. Jack
ModelAMike1930 11-13-2018 10:55 AM
Re: No Foot Starter
I got a tractor solenoid and a push button from ebay. I also got the needed cables there also. I reversed the started switch contact so it was always making contact. It works great.
daveymc29 11-16-2018 10:26 AM
Re: No Foot Starter
What issue? What page?
Bob C 11-16-2018 11:35 AM
Re: No Foot Starter
Here's a link. https://trisisdesign.com/
Davew 11-16-2018 01:30 PM
Re: No Foot Starter
How long has this been out? Looks like it would work pretty good.
Bob C 11-16-2018 04:08 PM
Re: No Foot Starter
2 Attachment(s)
These show up on Epay fairly often.
Jim/GA 11-16-2018 07:29 PM
Re: No Foot Starter
Have you considered these:
https://www.snydersantiqueauto.com/up-start
Not a solenoid. But hand operated starter switch.
wmws 11-16-2018 09:26 PM
Re: No Foot Starter
My starter works by pulling on a cable under the dash. That activates a lever on the starter switch to make the contact. It must be something aftermarket but it is the only one I have seen.
Benson 11-17-2018 11:24 AM
Re: No Foot Starter
Industrial Model A and B engines in 30's - combine, welders, water pump, sawmill used cables on starters. My Model B Diamond block had one with a governor.
Jason in TX 05-14-2019 10:56 AM
Re: No Foot Starter
2 Attachment(s)
In 1932, they used a pull cable. You could rig up a cable on your steering column pretty easily with the 1932 switch.
https://www.fordbarn.com/forum/attac...0&d=1557849383
https://www.fordbarn.com/forum/attac...1&d=1557849383
Jim Brierley 05-14-2019 11:02 AM
Re: No Foot Starter
1933-34 starters on their 4-cyl. cars had a remote switch similar to a solenoid, but foot operated. Those starters can be connected with a modern solenoid and either button operated or via a key-switch.
Ruth 05-14-2019 11:22 AM
Re: No Foot Starter
Haha, Neither is an A/C... Just sayin':rolleyes:
CarlG 05-14-2019 12:45 PM
Re: No Foot Starter
I am using a key-switch starter that utilizes a solenoid. It was a kit I bought from Merle's Garage in Parker, TX. The kit included all the necessary cables and wiring. Switch fits the regular Model A instrument panel, no holes to drill anywhere.
Jason in TX 05-14-2019 02:58 PM
Re: No Foot Starter
Interesting! I've been to his shop to do some work on an A and had no idea he was selling those kits. Good to know! :)
