The Ford Barn
-   -   Release bearing to shaft clearance (https://www.fordbarn.com/forum/showthread.php?t=253156)
36coupe 10-15-2018 03:52 PM
I am making a sleeve for the T170 to be able to fit in earlier throw out bearing to the transmission. What clearance should I have between the ID of the bearing and the OD of the transmission shift? I was wondering if it should be 1-2 thousandth or 4-5 thousandth.
